Used my Rebar today, working on assembling a poly AR lower. The file is very good for the task.
Used it as a mirror while shaving this morning. (Image removed from quote.)
I do carry Leatherman Squirt PS4 Multipurpose Hand Tool for my everyday outdoors. Its best beacuse it can be used for mulitple applications for many scenario situations.
I used my Crunch as a handle for a strong needle with which I removed the rivets of my watche's strap. Very nice tool that Crunch, I use it much more than I thought I would. A locking plier acts as a regular plier also when needed, It could be used as a minimalist tool in place of a Skeletool in my opinion, if only it had the bit holder.
It doesn't have a bit driver, just one Philips and three straight drivers. But I have a hex holder adapted for the Philips so no problem. I'll compare the Crunch and the Skeletool as companions to a Swisschamp for a light EDC during the next months.
Quote from: kkokkolis on December 18, 2014, 12:25:32 PMIt doesn't have a bit driver, just one Philips and three straight drivers. But I have a hex holder adapted for the Philips so no problem. I'll compare the Crunch and the Skeletool as companions to a Swisschamp for a light EDC during the next months.Arhhh, but it does have a bit driver. You just haven't found it yet.
Forgot about that, you are absolutely right. So I can use my Victorinox ratchet extender with it, that's awesome.So, a Swisschamp XLT and a lightweight tool with locking strong pliers, a hex adapter and a serrated blade. I won't miss anything if I add the ratchet, the extender and the hex bit holder in a Skinth. I bet that the Shield 2XL will leave me space for even more. We'll see in a couple of years months when I'll receive my Skinths.
Quote from: zoidberg on December 18, 2014, 12:37:35 PMQuote from: kkokkolis on December 18, 2014, 12:25:32 PMIt doesn't have a bit driver, just one Philips and three straight drivers. But I have a hex holder adapted for the Philips so no problem. I'll compare the Crunch and the Skeletool as companions to a Swisschamp for a light EDC during the next months.Arhhh, but it does have a bit driver. You just haven't found it yet. Here you go. I'm not telling you where the wire stripper is though.
(Image removed from quote.)Had to cut a 2x3 wave did the trick
