I received the wire strippers today and for 10 bucks they are not bad. They take some getting used to because if you press to hard they cut the wire and not hard enough they don't do anything. I quick test them on some CAT5E strands and it worked pretty well once I got the hang of it. I replaced the V-Cutter with this, so I am going to try and cut the V-Cutter down to fit next to it, but I know I like pictures so here are some of it on my SOG:
Next to my Charge TTI and in the Handle
A little Closer up but upside down
Strips 12, 14, 16, 18, 20, 22, 24 Gauge wire
Stripping some CAT5E strands
Hope this helps
