As said previously, traditionally, springs, saw mill blades and files have been used to make knives.As is my understanding, however, you need to first use heat, followed by low rate cooling to lower the temper of the steel so that you can work on it (shape it, cut it) and then again use the heat, with faster rate cooling to harden the steel and give it the properties (hardness, elasticity) you desire.I have, however seen these springs just cut and bolted onto a metal pipe bit to make a simple pick axe
That appears to be an old Land Rover leaf spring pack.
Quote from: Mr. Whippy on April 12, 2011, 08:04:03 PMThat appears to be an old Land Rover leaf spring pack.There was a 'Rover' stamp on one piece
