Leatherman MUT Scissors! (SUPER Pic Heavy)
ca Offline Metropolicity
  • Hack Virtuoso
on: December 21, 2011, 04:13:33 AM
I have to admit, I stole this 'idea' from a very great post/mod from Silverwarior.
Having had a MUT for a number of months now and having never done anything with it, it made me remember why! SCISSORS!
As soon as SW posted his mod of adding tweezers and scissors, I immediately went to my parts drawer and found my extra pair of Surge scissors, squared them up and I was hit with the bug again.
Everything seemed to line up really really well, but things would be so much darker than the shining optimism that I had initially.
So I go ahead, took a Surge pivot screw, shimmed up the gap with some bronze washers and tightened it up. Little did I know this would take MUCH more work than I anticipated.
The next problem was the back spring. On a Surge, the liner lock stops the scissors from rotating and the back spring engages and everything is cuttingly happy. The advantage of that design is that when folded back, the scissors aren't sprung and slides back in with no resistance.
After 3 different attempts at solutions (including using a meltable polymer to fill the gap, using aluminum foil to make a spacer and super gluing the crap out of it) I finally thought, I am going to pin this sucker.
Drilling a tiny hole with my carbide bits was easy, and then trimming a nail to fit into the hole was even easier.
I peened the back side of the pin so that it would stay put and sanded it flat on the belt sander.
Installing the back spring, and then installing it into the MUT.
Then the dark side of this mod reared its ugly head. I knew this would be a problem as soon as I thought to pin it. The permanent backspring pin pushes the scissors out into it's natural unsprung state.
SOOOOOOOO...
20 mins later I had a solution! A rotating lock!
I took a screw driver part from a knock off SAK and starting hacking away into a plate to swing in the way of the scissors. A bolt was then trimmed down and the threads cut off on the inside of the screw so that when tightened, the plate would be able to swing freely. A set of thin washers completes the mechanism.
Then, a corresponding hole was drilled and tapped. The bolt is trimmed so that it doesn't interfere with plier head closing.
After installing the whole thing together again, I encountered yet another problem. The locking plate would swing freely and could slip off the scissors. I imagined the MUT in my pocket and the scissors deploying with great vigor...no thank you.
Solution: milling a little notch in the scissor handle so that plate will stop wiggling. Works like a charm. A little squeeze on the scissor handle loosens the plate and it swings out of the way.
And now...for some hero shots:
Thanks to Silverwarior for reminding me about my MUT!
HACK ON!
Why stop now?
Shapeways - Metro's Q-branch:
Re: Leatherman MUT Scissors! (SUPER Pic Heavy)
Reply #1 on: December 21, 2011, 05:26:01 AM
 8) 8) 8) 8) mod mate  :salute: :salute: :salute:
I wonder if a Wingman's scissors would be a possible option instead of the Surge's  :think: :think:, I can not seem to find my Wingman  :ahhh :ahhh
  • Hack Virtuoso
Reply #2 on: December 21, 2011, 05:51:03 AM
ugg, I am looking at Wingman now and I don't want any parts of that horrid tool. I regret trading stuff for it....
BUT they would fit.
Why stop now?
ca Offline Beerplumber
Reply #3 on: December 21, 2011, 08:09:24 AM
Genius! :gimme:
00 Offline WWW
Reply #4 on: December 21, 2011, 09:50:12 PM
A fantastic work sir!! But a hell lot of trouble. I was just wondering if the lock wont be sticking into your hand when you're using the blade or the saw ???? Any ways great job  :tu:
Reply #5 on: December 22, 2011, 06:02:17 AM
Nice mod- but is the constant tension going to kill the spring?
  • Hack Virtuoso
Reply #6 on: December 22, 2011, 06:05:49 AM
Only time will tell, I've been playing and stressing the back spring so see if it will fail and so far it hasn't shown any signs of fatigue.
Why stop now?
my Offline silverwarior
Reply #7 on: December 22, 2011, 06:36:15 AM
Great mod there, Metro  :tu: I did have the same ideo but after I saw how the scissors works with liner locks in the Surge, I dropped the idea. Nice work on the rotating lock & I really like the look of it. Glad that I've reminded you not to give up on your MUT  :cheers:
ca Offline Syph007
  • SAK Surgeon
Reply #8 on: December 23, 2011, 12:13:00 AM
Nice modding, I always enjoy seeing how others tackle problems.
This didn't make me want a MUT though, but it does now make me want a surge.   As I was reading I was thinking, might as well just get a surge and the MUT doesn't have much else to offer for me.  Seems like the MUT is really only good if you are a shooter.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
  • Hack Virtuoso
Reply #9 on: December 23, 2011, 12:15:30 AM
One word friend.
Hammer.
Why stop now?
us Offline Accujohn
Reply #10 on: December 23, 2011, 02:01:49 AM
I think he is sharing his mod with us all and not really trying to compare it to other tools or sell us on the MUT.
Nice work... And great effort!
Reply #11 on: December 24, 2011, 07:49:07 PM
Great workmanship there Eric :salute: I'm sitting here trying to come up with a better solution than the rotating lock, but so far, nothing. :think: :think:
  • Hack Virtuoso
Reply #12 on: December 24, 2011, 07:55:06 PM
i figure it was fitting for this particular tool since there are is already a rotating lock, you now know what kind of mind set I was in :)
Thanks Bob! Always nice to get approval from a professional.
Why stop now?
Reply #13 on: December 24, 2011, 08:16:47 PM
Oh yeh, I hadn't thought of that! :D
  • Hack Virtuoso
MUT Scissors usage update.
Reply #14 on: January 02, 2012, 08:16:50 AM
I want to update you guys on the usage of this mod. There was worry about the constant tension when they were closed and after a whole week of use, closing, opening, the spring hasn't shown any signs of stress.
Things are looking good :)
Here's a little matchy match combo, a SRM Tan G10 763 with some OD lanyard.
« Last Edit: January 02, 2012, 08:20:11 AM by Metropolicity »
Why stop now?
gb Offline 5hif7y
  • tooled up
Reply #15 on: January 02, 2012, 04:18:25 PM
nice work there mate. very impressive. looks like a great tool now.
-----5hif7y-----
Offline shabodah
  • New User
Reply #16 on: October 25, 2013, 04:14:56 PM
I'm curious if this mod would have worked better if you had been replacing the saw blade instead.
Offline Trebor Redins
Reply #17 on: October 17, 2019, 01:33:07 AM
Does anyone have the pictures from this mod archived?
Thanks!
  • Hack Virtuoso
Reply #18 on: October 17, 2019, 04:24:20 PM
Thanks!
I can't even repost them, or find the tool. I must have sold it!
Why stop now?
  • Hack Virtuoso
Reply #19 on: April 19, 2020, 05:09:54 AM
Thanks!
Found them!
Why stop now?
