I have a Wave and it finally got dull. The only sharpener i had with me was a "v-sharpener" by Victorinox which works AMAZING on SAKs.I ran my wave thru it and yes, it sharpened it, but I am guessing it sharpened it at a different angle.How do I get it back to the Leatherman factory default? Take it to a knife store to do professionally?
So Leatherman plain blades have a factory 32º angle, so they can be sharpened with the 30º (15+15) setting of the Sharpmaker, for example.
the bevel was uneven so I wasn't catching the cutting edge where the blade curves up.
Okay, here's my yet different opinion.When I need to sharpen a new blade, if it's a blade that's going to see heavy use and possibly abuse (the kinds of hack and slash stuff I typically use a knife like my Endura for), I reprofile the edge to be a convex grind.I start off shallow, about 20º or so (so far I do all my sharpening by hand on a stone) to pare the edge back a bit. At this point, I'm not actually working on the edge, but the back portion of the grind of the edge, at the body of the blade.Once I'm happy with that, generally got it even and extended the grind a mm or so, I step up my angle to about 25º and repeat. Then to about 30º and repeat.At this point I step up a very small amount, just a couple of degrees until I'm happy with it, then up again another couple of degrees. At this point I'm shortening the grind of the edge, rounding it off a little bit. I continue until I get an even and smooth edge I'm happy with, and then finish the edge from there.This gives me an edge very much like you'd put on an axe. I prefer this for heavy duty knives (and beaters, like my Tenacious and Resilience) and MT's that I'm going to be using roughly, because while it is a tad less sharp, it's a lot more durable of an edge, and holds longer than a simple flat grind edge. I don't do this for my EDC knives, such as my Stretch, or any of my SAK's however. I prefer regular flat grinding because it does produce a sharper edge.
That stock edge is definitely substandard. Did it come like that out of the box? That should never have made it past QC.
