Figured starting a unique tricks would be pretty neat for everyone, I'm sure there's some trick that not everyone knows,, so let's hear what you know of, I'll start.. JR
First tip, if your going to pack a bail out bag, but don't want to carry anything heavy, nor spend a lot for everything, check out the travel section in most store,
Worried about loosing anything? A little tricky to do but can be done, if you have paracord, you need a couple electric fittings and one of those funky springy bracelets. Take all the cord out of the paracord and fit the and slip it over the bracelet, then crimp the ends on,
How about duct tap as a keychain? 2" pin and wrap it around!
Or as a wallet or pocket carry? Know those credit cards you get in the mail that want you to buy into them? And they give you a fake, well there is a use for them after all, wrap the tape around them!
One last little trick I did but don't have a pic is a wallet pen, some of those can be really pricy, well, here's something for cheap, all you need is a hair pin, ink cartage, and heat shrink tubing. Place the pin and cartage side by side and slip the heat shrink over, and shrink, good to go!
