Well, I finally got the seemingly obvious idea of asking Maglite itself. Here's the asnwer (I asked about 10 hours ago. These guys are good.) Rodian[cringe]:We do not recommend the use of rechargeable batteries in standard or LED/ Maglites® because rechargeable batteries are rated at 1.2 volts, whereas standard batteries are rated at 1.5 volts. By using rechargeable batteries you loose .3 volts per battery, which means you will have less light output or a dimmer light. Another reason is because the discharge curve on rechargeable batteries stays at a higher voltage longer than standard batteries so the lamp/LED life is less.If you can live with this go for it, it will not damge the light.
Yes I Know there's a circuit controlling power to the bulb (LED), but RCR's have 3.6 volts against the standard 3 volts. Assuming the circuit of the Tk10 can handle 7.2 volts or more, how long do you think can the circuit or the LED withstand the inflow of voltage? I'm sure runtime/s will be affected in actual use. As advertise by Fenix, the Tk10, on turbo mode, using the standard 3v lithium, should only be use for 10 minutes. I'm not sure if it's the same using RCR's.
Quote from: Rodion on July 26, 2008, 03:16:08 AMAnother reason is because the discharge curve on rechargeable batteries stays at a higher voltage longer than standard batteries so the lamp/LED life is less.This is irrational thinking, IMO.
