Compatibility questions
us Offline irona
on: January 18, 2017, 04:37:48 AM
Hi, I'm very interested in modding my PST to exchange the file with a saw, but I have some concern about the tools fitting. Does anyone with a digital caliper have the measurements of the thickness (of the area around the pivot hole) of the wave/charge saw, and of the surge saw/file holder? Thanks a ton!
Re: Compatibility questions
Reply #1 on: January 18, 2017, 02:06:21 PM
That's something I plan to do with a PST II soon.   Someone here did it before, but used a cut down SOG saw.
au Offline pietervn
Reply #2 on: January 21, 2017, 08:58:09 AM
Yip, I fitted a SOG saw into a PST body. Not difficult at all.
Read all about it here:
http://forum.multitool.org/index.php/topic,48498.0.html
Pete
« Last Edit: January 21, 2017, 10:57:02 AM by pietervn »
us Offline irona
Reply #3 on: January 22, 2017, 02:32:37 AM
Pete
That's awesome! So you didn't have to mess with the locking notch on the blade at all?
au Offline pietervn
Reply #4 on: January 22, 2017, 08:56:02 AM
That is correct. Once the bottom was aligned, I could see how much needed to be removed from the top. Go slow, if you remove to much it cannot be put back. With the top flush with the handle the locking mechanism lined up as if it was fitted from the factory.
I can take additional pics of the saw inside the tool if you want.
Cheers,
Pete
us Offline irona
Reply #5 on: January 22, 2017, 05:23:44 PM
Cheers,
Pete
By the top do you mean the spine of the saw or the top part of the pivot area?
au Offline pietervn
Reply #6 on: January 23, 2017, 05:24:42 AM
I mean the whole top side of the saw blade from the tip to the pivot end. When I sanded mine down I used a piece of glass and clamped the sanding paper to it. That way I got a perfectly flat surface to sand on.
I hope it is clear.
Pete
