Fatwood match: Just a thought
us Offline Lynn LeFey
on: December 02, 2017, 07:39:22 PM
I'm just curious why I've never seen this. I've seen people scrape the heads of matches off to make their own of various materials. It seems like this would work. I just don't have the materials to make them. If someone runs with this idea, please post back on results.
Re: Fatwood match: Just a thought
Reply #1 on: December 02, 2017, 08:35:54 PM
In theory it should work fine :think: but it might work to good and catch yourself on fire :ahhh :D
Reply #2 on: December 02, 2017, 09:12:07 PM
Isn't that what we awl want? Dangerous fire making stuff? :dd:
england Offline Kev D
Reply #3 on: December 02, 2017, 10:44:41 PM
Mmmmmmmmmm fire
Reply #4 on: December 03, 2017, 05:56:03 AM
Brilliant idea, but I'm afraid someone has beat you to it.  There are many such products available.
Reply #5 on: December 03, 2017, 05:15:37 PM
Well... yes and no. They are firestarters, but all of those are compressed sawdust with a binder (or something similar), not fatwood. And they're not matches.
But yeah, same idea.
Offline Mattexian
Reply #6 on: December 05, 2017, 07:16:42 AM
My experience with fatwood is that it tends to dry out if you cut it up into useable sizes then store it away for a while, like a year or less.  There's nothing wrong with pine slivers, they're still very flammable, work great for kindling and tinder, but the resin would evaporate away.  It worked much better to build the kindling pile with fatwood slivers wedged thru it, then light a match and ignite a long sliver of fatwood and use that to ignite the pile at various points.
I'm probably a little spoiled, in that i live in an area where old pine stumps are plentiful in the woods, so I can collect "fresh" fatwood any time I'm out.
Sent from my SM-J727T using Tapatalk
R
il Offline pomsbz
Reply #7 on: December 05, 2017, 07:33:03 AM
I'm sure that could be fixed by some kind of clear coating. I'd be in for fatwood matches though to be honest, UCO stormproof matches are probably a better bet though. Won't burn as long but will burn far more furiously and really are stormproof.
« Last Edit: December 05, 2017, 07:37:46 AM by pomsbz »
hr Offline styx
Reply #8 on: December 05, 2017, 10:20:48 AM
so in theory you could take small sticks (no larger than pencil sized) of some softer wood, put them in melted lard or any other sort of fat and then dip them in melted wax which would seal them. this sounds a bit too simple but might be worth a shot for those who like to experiment
Reply #9 on: December 05, 2017, 05:33:34 PM
There's really no point in coating an object in fat then in wax. Wax is flammable.
And, by the way, a bit related, corrugated cardboard, dipped in wax is great. The hollow chambers in the cardboard soak up the wax, and the whole thing works great for wicking the wax up to burn.
The 'resin evaporates' issue isn't one I was aware of. I've never found fatwood in the wild, but I'm from a place without a lot of pine.
Reply #10 on: December 05, 2017, 06:39:42 PM
Yes. Fats and oils are more readily absorbed by most types of wood than wax. However, not really worth making. I tried before. Now for cotton balls, a good mix is 50/50 beeswax and animal fat. Best part is, whatever is left after it cools is great for leather and wood. The wood or leather will absorb the oils and the wax water proofs it for a while. Makes for a great polish also.
Melting pine pitch and dipping some cotton balls works even better. Stuff goes up like gasoline.
« Last Edit: December 05, 2017, 06:49:47 PM by ducttapetech »
Reply #11 on: December 05, 2017, 06:53:00 PM
I forget the you tubers name, he had made some this way. They seemed to work pretty good. I have seen  people use fatwood for viking matches also.
« Last Edit: December 05, 2017, 06:54:24 PM by ducttapetech »
il Offline pomsbz
Reply #12 on: December 05, 2017, 08:13:28 PM
Just made myself up a batch of waxed sisal rope (4 strand) tonight. Once cut down it will make a great long burning waterproof 'match' once lit and this stuff up lights nice and easy from a firesteel should you be so desperate as to have to use one. :D
« Last Edit: December 05, 2017, 08:16:28 PM by pomsbz »
Reply #13 on: December 05, 2017, 08:49:54 PM
 I do that same thing with jute.  :tu:
  • Benner fan club #003
Reply #14 on: December 06, 2017, 01:10:32 AM
This is what I call a fatwood or firesteel match...a little tinder and the match is held with the striker when scraping. Twigs, spent matchsticks, birthday candles etc. can be used. It works well with small firesteels (like the tiny one glued to the bottom of a plastic match safe) because the tinder travels with the sparks..keeping them concentrated.
* fatmatch01.jpg (Filesize: 54.11 KB)
* fatmatch02.jpg (Filesize: 36.67 KB)
* fatmatch03.jpg (Filesize: 28.91 KB)
* fatmatch04.jpg (Filesize: 46.92 KB)
Reply #15 on: December 06, 2017, 01:15:24 AM
more...
* fatmatch101.jpg (Filesize: 97.64 KB)
* fatmatch103.jpg (Filesize: 93.46 KB)
Reply #16 on: December 06, 2017, 01:18:17 AM
I've also made DIY SAs...on storm matches. I might have put too much compound on them...they were a bit zesty :ahhh
They worked well, but I don't think it's worth the effort.
* diy_matches001.jpg (Filesize: 23.17 KB)
* diy_matches002.jpg (Filesize: 24.37 KB)
Reply #17 on: December 06, 2017, 01:23:45 AM
Spork!  :ahhh :ahhh
Reply #18 on: December 06, 2017, 01:24:58 AM
No match can be too zesty.  :P :rofl:
il Offline pomsbz
Reply #19 on: December 06, 2017, 07:10:00 AM
Sorry, mine was jute, was writing it too fast and screwed up.
il Offline pomsbz
Reply #20 on: December 06, 2017, 07:11:24 AM
screwed up again, sigh.
Reply #21 on: December 06, 2017, 10:16:01 AM
Nice to see you Spork!
Reply #22 on: December 07, 2017, 07:58:26 PM
:salute:
