Problem with the new SOG Power Access Deluxe
Wspeed · 117 · 10434
Re: Problem with the new SOG Power Access Deluxe
Reply #60 on: May 06, 2018, 04:31:32 PM
Excellent.  :tu:
Reply #61 on: May 06, 2018, 04:33:50 PM
us Offline gerleatherberman
Reply #62 on: May 06, 2018, 06:53:32 PM
That is awesome SOG is taking care of the problem so quickly! Hopefully you'll have the new one in a week or so.  :cheers:
I took a quick photo for you. :D
SOG on the Rocks by None, on Flickr
Reply #63 on: May 06, 2018, 07:05:02 PM
Thanks GLBM  :cheers:
I took pics before it was wrapped up  :rofl:
Hopefully it won’t be long  :tu: :like:
« Last Edit: May 06, 2018, 07:06:10 PM by Wspeed »
Reply #64 on: May 07, 2018, 01:12:11 AM
You're welcome, Wspeed!
So far today I realized one important thing about the Access Deluxe. They did fairly well on the amount of capability vs. the tool's cost. Except the file. I think SOG labeled the "file' incorrectly. The proper name is 'butter knife' or 'butter spreader'. :tu:
Reply #65 on: May 07, 2018, 01:18:14 AM
You never know what else we can label that bit of metal with
It will be interesting to see what other members
Will come up with when we do the challenge  :cheers:
Offline overclock
  • New User
Reply #66 on: May 07, 2018, 08:33:25 AM
Hello guys, as a long time lurker I have to chime in on this particular multitool.I have never used a SOG multi and found this model ticking a lot of boxes for my uses. So I thought I would dip my toes in the SOG waters with the PAD. I ordered from Amazon and received it on friday. I EDC'd it at my job on sat. for 12 hrs. Used the pliers a few times nothing hard or heavy. No cutting wires, no use of any of the tools. Today I was sitting and watching youtube relaxing just fliping out the blades and tools. I noticed that the side with the bit driver seemed a little tight.I thought I would flip that side out a little more thinking that it would loosen up after a few cycles. I barely worked that side 10 min. when "snap" one of the small arms that springs the lock tabs broke. I was shocked, this is supposed to be from the "industrial tool" line. These arms appear to be what could be a weak point as they are no thicker than toothpicks.I really wanted to like this tool but alas its going back. Not a good first impression for SOG.  :facepalm:
Reply #67 on: May 07, 2018, 08:41:56 AM
Welcome to the boards overclock.   :cheers:
Reply #68 on: May 07, 2018, 12:28:58 PM
Hi overclock and welcome to  :MTO: :cheers:
I am sorry to hear that it’s snapped at the spring
Have you got any pics of the PAD you could show
With the broken part
Like you this is my first SOG as well
If you do get a replacement in time
There is a challenge starting on the 1st of June
And we would love to have you join us :tu: :like:
Thanks Wspeed :salute:
Reply #69 on: May 07, 2018, 01:19:16 PM
Welcome to MT.o, overclock! Sorry to hear what happened!
I am in no way running to SOG's defense,  but some spring tabs on other locking MTs (ex. Leatherman ST300, Rebar, and some others) are about the same thickness(about a toothpick) and don't snap.
In recent years,  SOG has released a bunch of new multitools that share one thing in common. That is poor manufacturing techniques. This has ultimately led to a significantly higher number of "modern SOG designs" having major failures.
You have two ways to approach the problem from my perspective.
1. Return the tool to the retail source you purchased it from for a refund. Then buy something with a better reputation (ex. LM ST300 or Victorinox SwissTool)
OR
2. Fill out the return process on SOG's website and send it in for "repair or replacement".
I would send it in for replacement myself. But, that boils down to how much you liked the tool before it failed. SOG is good about replacing broken tools. But, that is no guarantee it won't happen again.
So it is a roll of the dice sending it in to SOG, as the replacement may fail as well. On the other hand, the other options(Leatherman and Victorinox ) are quite a bit more expensive. So you could theoretically send it back to SOG multiple times before reaching the cost of the other brands. Your odds of receiving a better "checked" tool from a replacement at SOG are good.
Whatever you choose to do, we welcome you to MT.o, overclock! :cheers:
es Offline ThePeacent
Reply #70 on: May 07, 2018, 02:12:32 PM
man this seems to be happening too many times with newer SOGs.  :ahhh
You rarely heard about problems with the oldies  :facepalm:
also welcome to the forums overclock and good luck!!!   :cheers:
My toys:
Reply #71 on: May 07, 2018, 04:17:56 PM
Indeed. Very true!
I know SOG has made huge attempts at being innovative, but they should have stuck with just two things on the old models.
1. Use an independently installed piece of spring steel (ex. Piano lock cut springs or single spring for all tools). As a new spring can be riveted into the handle if it breaks AND trying to spring harden a small portion of the newer style steel frame is iffy at best.
2. U-shape handle frame. The new Two-piece frame instead of the older u-shaped frames lead to handle breakage. BUT! If they would use a piece of independently spring-hardened steel for the locks, they could properly harden the two piece frame to a reasonable level and avoid frame breakage under heavy pressure .
From my observations, these seem to be a majority of the issues. QC based issues include screw tightness, poor file cutting, and iffy tool hardening processes. :facepalm:
« Last Edit: May 07, 2018, 04:20:30 PM by gerleatherberman »
Reply #72 on: May 08, 2018, 02:33:10 PM
My PAD has been dropped off today at UPS
To be returned to SOG  :salute:
Reply #73 on: May 08, 2018, 03:04:42 PM
May the wind be always at its' back! And return to you in due haste! :cheers:
Reply #74 on: May 08, 2018, 03:08:05 PM
I hope so :ahhh
Thanks GLBM  :cheers: :like: :like:
Reply #75 on: May 08, 2018, 03:30:07 PM
I hope so :ahhh
You're welcome, Wspeed!  :multi:
Offline overclock
  • New User
Reply #76 on: May 08, 2018, 04:53:02 PM
Hey guys, thank you for the warm welcome. I've lurked here off and on for several years and yes I love multitools so this site is great. I own many Leathermans ,also had and lost a Swisstool Sprirt X  (loved it). Lately I've been EDCing a Gerber Centerdrive.Like I said this was my first SOG and while I was impressed with the compound plier I wound up requesting a refund.I hope that you guys have better luck than me with this tool. I just think the basic design of those spring arms is poorly executed.I did snap a few pics on my cell phone and tried to attach them but the files were to big. I will try again. At this point I'm wondering if a SOG is in my future, I don't know. Maybe a Powerlock or Powerassist. Why is the Powergrab gone?
Reply #77 on: May 08, 2018, 05:40:36 PM
Hi overclock :tu:
Sorry to hear that you had to go for a refund
I just hope you haven’t been put off by SOG
The ones you mentioned look to be a good choice
So yes I am a bit disappointed that I had to
Send it back, but I do want to give SOG a
Chance, as with any new model there can always
Be teething problems
Hope you get better luck with your next tool  :tu: :cheers:
Reply #78 on: May 08, 2018, 05:49:40 PM
*What Wspeed said! :tu:
Overclock,
The PowerGrab was another high-failure MT, that was only available for a few months. Quite collectable now!
The PowerLock 2.0 is rock solid and while it is a very old design in the MT world, it is time-tested as a reliable and strong MT.
So, if you'll keep an eye on the upcoming PowerAccess Deluxe challenge, maybe that will either confirm your experience OR encourage you to try the PAD again. :tu:
Perhaps in a month or two, SOG will have tweaked the PAD design and re-release it. :multi:
Offline overclock
  • New User
Reply #79 on: May 08, 2018, 06:00:37 PM
Here are some resized pics from my cell phone, sorry for the poor quality.
* rsz_1rsz_20180506_162646.jpg (Filesize: 128.22 KB)
* rsz_1rsz_20180506_160948.jpg (Filesize: 115 KB)
* rsz_1rsz_1rsz_20180506_163823.jpg (Filesize: 52.69 KB)
Reply #80 on: May 08, 2018, 06:26:04 PM
Thanks overclock for posting the pics  :tu: :like:
SOG has got the link to this thread
So hopefully someone will take notice  :pok:
And start looking at these problems  :ahhh :ahhh
Thanks again  :tu:
Reply #81 on: May 08, 2018, 07:43:52 PM
The regular Access has the exact same spring system and that doesn't seem to be a common issue. I am hoping that spring breakage is a very rare problem. Although, as I keep running my mouth to say (hoping SOG will listen), trying to temper a little piece of spring steel inside of a hard steel handle is inherently going to have more failures than a piece of independently spring tempered steel riveted to the handle insides (like the older locking SOGs).
Reply #82 on: May 11, 2018, 07:20:52 PM
Update
Got a email from Chris@SOG yesterday
Here is a copy of the email:
We got the tool and have already done some diagnosis on it.
There were a couple issues we found and looking into the root cause.  Basically, one the handles we not hardened properly and the tolerance on a couple pieces were off.
Thanks again for sending it in and helping us diagnos problems.
Cheers
Chris
And got a email from Chris@SOG this morning to say
That the replacement PAD is being posted to me today :mail:
Reply #83 on: May 12, 2018, 02:38:58 AM
Wow. That is great! Seems they really did want to see what the problem was.
Glad your new one is on its' way to you, W! :cheers:
Reply #84 on: May 12, 2018, 12:19:38 PM
Reply #85 on: May 12, 2018, 02:43:04 PM
I know SOG is taking this seriously
So hopefully the little teething problems
Will be rectified ASAP
And it will be a nice reliable tool  :cheers:
Reply #86 on: May 12, 2018, 04:20:19 PM
SOG really needs a winner this time. I know the loses from the PowerGrab and poor sales of the PowerPlay were a big loss on their MT division budget.
The regular Acces has proven fairly successful, but that tool doesn't fill the needs of their heavy-duty fan base. The PAD is promising.
  • Bored
Reply #87 on: May 12, 2018, 06:44:05 PM
Quality has gone a bit downhill since the high point of the Powerduo
Reply #88 on: May 14, 2018, 03:52:27 PM
It’s now up to SOG to make sure
That quality gets better
They know what was wrong
With my PAD, after I send it back to SOG
So I hope that they are doing something
About these teething problems
As already said the file is no good
But I found the rest of the PAD really nice
And it would be a shame if QC
let’s SOG tools go down the drain  :tu:
us Offline NetsNJ
Reply #89 on: May 15, 2018, 06:31:22 AM
I love my power access, but have always worried about the lock bar springs being flimsy. Was not happy to see the breakage here.
Total Receipts: $122.41
PayPal Fees: $6.85
Net Balance: $115.56
Below Goal: $184.44
39%
