I have one... I like the blade shape and the and the feel of the handle.What I don't like is the tiny thumbstuds and the heavy backspring tension...it is somewhat difficult to open. I've heard the same from a friend on another forum who has handled an example. After the first inch or so of blade tip arc there is a definite increase in tension...sort of feels like a hump that has to be overcome on the tang.I think the backspring is a bit heavy because it does take some extra effort to disengage the lock.My preference is for tip-up and this one cannot be moved...right-hand tip-down only.
Quote from: SporK on March 29, 2009, 10:19:28 PM(Image removed from quote.)
I was wondering how well that works and how difficult it is to manipulate the little sliding stud to activate the manual lock?Could it be that the secondary lock is the reason for the stiffer blade opening effort?
Quote from: Micky d on March 30, 2009, 07:24:57 AMQuote from: SporK on March 29, 2009, 10:19:28 PM(Image removed from quote.) Maybe I just haven't gotten around to it yet
Quote from: ringzero on March 30, 2009, 05:24:36 AMI was wondering how well that works and how difficult it is to manipulate the little sliding stud to activate the manual lock?Could it be that the secondary lock is the reason for the stiffer blade opening effort?The manual lock is just a bar that slides into a slot in the tang. It is just a sliding piece with a ball detent.No, I don't think that is the reason for the stiff opening...it is the backspring and the corner of the tang.
Quote from: SporK on March 30, 2009, 04:59:58 PMQuote from: Micky d on March 30, 2009, 07:24:57 AMQuote from: SporK on March 29, 2009, 10:19:28 PM(Image removed from quote.) Maybe I just haven't gotten around to it yet Or your loosing your touch...
See the sharpish corner on the bottom rear of the tang?...that's what I believe is camming against the backspring and causing the extra tension.I was wrong about the secondary lock. The slide button operates a long arm ending at the rear of the knife...it blocks the end of the lock arm when engaged.
Sorry. I'm not taking it apart any farther. It's just an L-shaped bar with the button on the opposite end. The button is hollow holding the detent ball and spring.
You could be right about that with the blade closed, but as it is now...with the lock engaged...I can push the blade out far enough to expose the tip.Making it open easier might be a good trade off. I think the extra lock is really meant for securing the blade in the open position anyway.
Another possibility may be to grind down the coil spring powering the lock bar just a little bit.
