Don't snap shut your alox soldier
jzmtl · 29 · 2924
ca Offline jzmtl
on: April 12, 2009, 12:00:22 AM
After noticing that when the blade is pressed down while in closed position, the front portion will contact liner and dulled, I suspected the same thing would happen if the blade is snap shut. I tried it and sure enough, I can see reflection off the edge after the blade is snap shut.
So um, close the blade gently with both hands, don't snap it shut.
Re: Don't snap shut your alox soldier
Reply #1 on: April 12, 2009, 12:04:01 AM
I don't have that problem on any of mine and I have snapped them shut quite a lot.
ca Offline jzmtl
Reply #2 on: April 12, 2009, 12:05:43 AM
You gotta look at the edge with a jeweler's loupe under a 35w halogen lamp.
Reply #3 on: April 12, 2009, 12:06:49 AM
LOL!  :D
Still pretty sure it doesn't catch.
us Offline Gadget Guy
Reply #4 on: April 12, 2009, 12:08:37 AM
If I have to do that, who cares?  :pok:  :D
ca Offline jzmtl
Reply #5 on: April 12, 2009, 12:22:46 AM
I'm obsessed with keeping my blades razor sharp.  :(
us Offline Pacu
Reply #6 on: April 12, 2009, 12:31:18 AM
x2
:like:    :MTO:
Reply #7 on: April 12, 2009, 12:34:44 AM
I wish I had the skill to keep them razor sharp.  :(
gb Offline Craig
Reply #8 on: April 12, 2009, 01:01:12 AM
It takes me a huge amount of time to get a half decent edge, so any advice that can help me keep my knives sharp is greatly appreciated :tu:
Prone to daydreaming.
us Offline Pacu
Reply #9 on: April 12, 2009, 01:12:24 AM
invest in a quality whet stone. actually many stones of various grain.
:like:    :MTO:
us Offline felinevet
  • Banner Member
Reply #10 on: April 12, 2009, 01:19:49 AM
On a related note: Be very careful when closing your Wenger Standard Issue because it can easily hit the bail and nick.
T
us Offline Pacu
Reply #11 on: April 12, 2009, 01:26:06 AM
So it would be a good idea not to snap shut any knives...just to be on the safe side?
:like:    :MTO:
ca Offline jzmtl
Reply #12 on: April 12, 2009, 01:34:11 AM
Depends on the design, some allow blade to move inward from rest position a bit without hitting anything so those are fine. But it's only the slipjoint and back lock that have any snapping power anyway.
ca Offline jzmtl
Reply #13 on: April 12, 2009, 01:35:44 AM
You have a sharpmaker right? It's what I use as well, plus a home made strop. Nothing fancy about it, just practice a bit more and you'll get the hang of it.
us Offline bren10man
Reply #14 on: April 12, 2009, 03:35:48 AM
Guilty as charged..... :oops:
MOLON LABE!
Offline Anthony
  • Improvise.
Reply #15 on: April 12, 2009, 03:41:43 AM
I noticed this on my first SAK...after a long while of snapping the blade shut, I was sitting at my desk and coulden't understand why there was a bent edge on the blade since I never cut anything hard or hit metal.  Then I realized I DID hit metal..every time it snapped shut the blade hit metal.
Maybe it varies from SAK to SAK...the model I noticed it on was a Sportsman II.
us Offline Swiss Man
  • WIFE APPROVED
Reply #16 on: April 12, 2009, 03:58:34 AM
I personally think if you don't close the SI blade on the bail at least once then you don't own an SI. :D
Offline american lockpicker
Reply #17 on: April 12, 2009, 04:33:16 AM
That happened on my Brithish Army knife.  :(
us Offline NeitherExtreme
  • Marsh-wiggle
Reply #18 on: April 12, 2009, 04:45:57 AM
For what it's worth, I've noticed the same issue on LM Juice knives.
Reply #19 on: April 12, 2009, 05:25:42 AM
I`ve not noticed any of my SAKs doing this yet. But one of the good things about SAKs is they resharpen very easily. I have whacked the blade of the Wenger SI on the bail.   :ahhh   :D
scotland Offline Sea Monster
Reply #20 on: April 12, 2009, 05:55:05 AM
I just put my finger there to slow the blade down before it hits the liner!
Reply #21 on: April 12, 2009, 09:10:35 AM
I've never had that happen to my Soldiers/Farmers either :)
Offline max6166
Reply #22 on: April 12, 2009, 09:50:46 AM
I took apart a 84mm cellidor SAK to see what was going on once, and the blade was definitely hitting something when it closed. I think it was either a spaced or the backspring itself.
Since them, I have closed them all very gently. Seems like a strange design though - Couldn't they have left a little room so that blade wouldn't hit anything on closing?
Reply #23 on: April 12, 2009, 09:54:54 AM
I had a Vic soldier that used to dull when you snapped the blade shut .After chatting about it on SOSAK it appears that only some Vic Soldiers do this .
Dunc
gb Offline Roadie
  • Hello...is this thing on?
Reply #24 on: April 12, 2009, 01:51:21 PM
My SI doesn't have a bail :ahhh What do i own :ahhh Anyone got a bail i can borrow just so i can hit my blade against it :think: :D
hn Offline cliosguy
  • no nacimos con miedo...
Reply #25 on: April 12, 2009, 02:59:57 PM
It happens with the centofante too :(
A
Reply #26 on: April 12, 2009, 07:07:44 PM
I prefer a hollow rivet though.  :tu:
Reply #27 on: April 12, 2009, 09:24:43 PM
Last night after reading this thread I dug out the SI I keep in my pack and was fiddling around with it and whacked the blade on the bail again. Now I`ve got two nicks in the blade.   :ahhh    :D
00 Offline Bill.H
Reply #28 on: April 13, 2009, 04:18:38 AM
Go Here. Read.
I use paper wheels and follow up with a strop if I'm looking for a really sharp edge. For day to day usage I don't bother as I ruin it first time I use it hard anyway.
I like the Lansky for making new bevels. I'm just too lazy to put the extra effort it requires to do it freehand on a stone. Once the bevel is correct, the paper wheels are super fast and easy.
I purchased a 6" Ryobi grinder from HD several years ago for $40. Removed the guards, reversed the base, and put on a 8" set of paper wheels. Works very well, but I sometimes wish it turned a little slower, a little slip can mess it up cause it's working so fast.
