Should I ask what you use pliers for in the bedroom
That's one of the underlying beauties about the Swisschamp, it is by far the most sheeple friendly knife out there, even compared to other saks
Quote from: Micky d on April 29, 2009, 10:39:01 PMShould I ask what you use pliers for in the bedroom Not me, I use the reamer in the bedroom a lot. Sometimes the corkscrew
On the magnifier front I'll be interested to know what you think about the old and the new. Personally I prefer the new style (unlike most, I know). The main reason being the fact that it has a bigger diameter and so a better field of vision. Let us know what you think.
Although the new model with the larger plastic magnifier "should" be better at fire starting due to its larger focal length.
Quote from: Ben X on April 30, 2009, 09:33:08 AMQuote from: Micky d on April 29, 2009, 10:39:01 PMShould I ask what you use pliers for in the bedroom Not me, I use the reamer in the bedroom a lot. Sometimes the corkscrew At least it isn't for lady friends in need of a tiny magnifier.
Quote from: Nightshade on May 02, 2009, 06:07:10 AMAlthough the new model with the larger plastic magnifier "should" be better at fire starting due to its larger focal length. I tried to burn wood with the magnifiers of both Swisschamps today. I couldn't get either to make so much as a tiny burn spot on a piece of balsa wood.
I remember reading the same thing about the new file not being case hardened but I have no real evidence on it. IIRC it was over on SOSAK and I just don't have the will to try and do a search over there right now.
It may not be a very good fire starter, but it is an excellent magnifier....
