Hubeo Pocket Tool
WH867 · 17 · 8858
us Offline WH867
Hubeo Pocket Tool
on: May 15, 2009, 03:51:53 AM
My latest addition.  Showed up today.     I gave it a good scrub but tried not to remove any petina.  This is a really solid feeling tool that other than the wire cutters does'nt look to have seen much use.  Seems very well built and still ready to work.  Its slightly smaller than a Sog toolclip but is slightly heavier.
* 000_3259 (Small).JPG (Filesize: 15.67 KB)
* 000_3262 (Small).JPG (Filesize: 11.86 KB)
* 000_3264 (Small).JPG (Filesize: 30.23 KB)
* 000_3267 (Small).JPG (Filesize: 28.35 KB)
Dennis
us Offline WH867
Re: Hubeo Pocket Tool
Reply #1 on: May 15, 2009, 03:52:41 AM
couple more.
* 000_3271 (Small).JPG (Filesize: 35.27 KB)
* 000_3273 (Small).JPG (Filesize: 22.49 KB)
* 000_3275 (Small).JPG (Filesize: 21.9 KB)
Dennis
Offline Anthony
  • Improvise.
Reply #2 on: May 15, 2009, 03:55:39 AM
That is a cool looking tool...it looks like the grandfather of the Toolclip!
Reply #3 on: May 15, 2009, 03:57:09 AM
yeah but it looks more ergonomic :think: :D
Offline I'm Still Bison
Reply #4 on: May 15, 2009, 04:00:32 AM
If only Bob wasn't so tied up in Springtime home projects,he'd probably be able to give a run-down of it's lineage.My thoughts are that it's 1950's vintage.No matter it's age,I like it.
I
us Offline WH867
Reply #5 on: May 15, 2009, 04:02:05 AM
And actually a better tool selection than the Toolclip since it has a phillips.    Also 2 different wire cutters.
Dennis
Offline Anthony
  • Improvise.
Reply #6 on: May 15, 2009, 04:03:04 AM
Isn't that about the time Phillips head screws started being widely used?  Or was it the 1960's? :think:
Reply #7 on: May 15, 2009, 04:05:02 AM
Nice one Dennis :tu:  There aren't many of these old beauties around any more. They are the best pre-Leatherman multitool in my opinion. :salute:
Made in Solingen Germany by Hugo Berns, sometime in the early 60's
Reply #8 on: May 15, 2009, 04:08:25 AM
You really have to wonder why it didn't catch on in a big way. Was it too "exotic"?
I
us Offline WH867
Reply #9 on: May 15, 2009, 04:16:03 AM
Is this the only model  Hubeo made?    I suppose you have one NIB :pok: :D
Dennis
Reply #10 on: May 15, 2009, 04:31:32 AM
Heh-heh, I wish! :D
Mine is in pretty decent shape though. Keep in mind these were made before the widespread availability of stainless steel. To resist corrosion, all of the outer surfaces were nickel plated. Nickel plating eventually flakes off, more so on tools that were carried and used a lot.
Here's mine (in the middle, sandwiched between a Hi-Test tool (made in Japan, top) and a Seaboard Steel tool (made in France, bottom)
Reply #11 on: May 15, 2009, 07:33:28 AM
Interesting piece that :tu:
ca Offline jzmtl
Reply #12 on: May 15, 2009, 09:29:43 AM
I like how the handle curves around the body instead of sticking out like toolclip.
Reply #13 on: May 16, 2009, 01:02:18 PM
Yeah, love the lines on that handle :tu:
Reply #14 on: May 16, 2009, 03:05:10 PM
That's an impressive bit of MT history  :tu:
Neil
Reply #15 on: May 16, 2009, 03:19:36 PM
Dennis great pick up  8) 8) 8) 8) 8)
You are right Bob yours looks all banged up with the nickel plating chipped off  :P :P. You sure you haven't got it's box as well :pok: :pok: :D :D
Bob I really like the group shot  :salute: . I really need to look at the pre Leatherman section of the encyclopedia , then again given my recent buying spree  ::) ::) maybe I need to keep well away from it. :D
« Last Edit: May 16, 2009, 03:30:01 PM by MultiMat »
Reply #16 on: May 23, 2009, 09:56:13 PM
I like that.  :)
