HELP.....shoulder strap needed
Guest · 26 · 2911
Flash
  • Guest
on: May 26, 2009, 11:57:23 AM
Dudes and dudesses,
I have just got the below and it is a quality however....I am quite tall and need a longer shoulder strap.
Does anyone have an adjustable shoulder strap in green with clips on either end that is around 60" long and 1 1/2" or 2" wide?
I will buy it from you if I can.
Failing that does anyone know of a place where I can buy the same.
Many thanks,
Nick
Re: HELP.....shoulder strap needed
Reply #1 on: May 26, 2009, 11:59:15 AM
Maxpedition will do one I expect.  Costly though no doubt.
Reply #2 on: May 26, 2009, 12:01:52 PM
Flash
  • Guest
Reply #3 on: May 26, 2009, 12:09:36 PM
Thanks Ben.....problem is I dont know the length and shipping to England is sometimes a problem for Maxp :(
scotland Offline Nikos
  • Why is it doing that?
Reply #5 on: May 26, 2009, 12:16:03 PM
Problem is it's "just" 47in long... ::) :D
Offline Tinnie
  • I hate Velcro!
Reply #6 on: May 26, 2009, 12:34:24 PM
You could make one from webbing or what not from a surplus store....but then that's effort :P
Reply #7 on: May 26, 2009, 02:13:54 PM
That's ok, it's not going around his waist :angel:
Reply #8 on: May 26, 2009, 02:36:41 PM
:rofl: :dnft: :pok: :D
Offline cgk
Reply #9 on: May 26, 2009, 02:39:08 PM
I would look for a local seamstress to fashion one up, probably cheaper than ordering on.  I have the exact bag in black, can't believe that strap isn't long enough.....then again Im a little guy....
it Offline sardauker
  • Just arrived
Reply #10 on: May 26, 2009, 02:50:16 PM
why don't you thread one with some green paracord, bracelet style?
you can make it adjustable using 3 clips and some rings...
Flash
  • Guest
Reply #11 on: May 26, 2009, 10:11:15 PM
OK....the Maxp one at 47 " is TOO small.  I need 60 " min.
Anyone know where I can buy 2" wide webbing in green so I can make a go of it myself?
Your help is as ever appreciated,
nick
Reply #12 on: May 26, 2009, 11:42:33 PM
nick
60"?!?!  :o
Are you wanting to drag it along 4ft behind you or something?  :D
Reply #13 on: May 27, 2009, 02:02:38 AM
In Staffs - http://www.haywoodproducts.com/webbingstrapping
They do a custom service by the look of it so should be able to help.
You might be able to go blag a couple of metres if not :D
« Last Edit: May 27, 2009, 02:04:56 AM by nuphoria »
Reply #14 on: May 27, 2009, 02:07:17 AM
« Last Edit: May 27, 2009, 02:09:28 AM by nuphoria »
ph Offline duckman1975
  • Naked without my multitool!
Reply #15 on: May 27, 2009, 02:12:35 AM
Reply #16 on: May 27, 2009, 02:15:33 AM
Why do you try this one:
http://www.pacsafe.com/www/index.php?_room=3&_action=detail&id=68
I'm afraid that won't fit the big fella... he needs BIG MACHO STRAPPING!  8)
Offline I'm Still Bison
Reply #17 on: May 27, 2009, 05:29:25 AM
 Have any connections in the Airborne? A parachute rigger could whip up one in no time.
I
Flash
  • Guest
Reply #18 on: May 27, 2009, 09:26:10 AM
Thanks everyone....I ended up buying several metres of webbing strapping with some triglides etc.  I will let you all know how it works out when it arrives.
Thanks again all,
Nick
PS Yes I am fat....but I can loose weight you lot will always be ugly  :P
Actually, thats a lie.....I cant loose weight, i have tried and failed  :cry:
Reply #19 on: May 27, 2009, 05:27:28 PM
Thanks again all,
Nick
... and you're also ugly.  :P :D
Reply #20 on: May 27, 2009, 06:20:54 PM
Thanks again all,
Nick
:rofl: :rofl:
Flash
  • Guest
Reply #21 on: May 27, 2009, 08:13:57 PM
Yeah that's right, Pick on the fat kid....he has no feelings   :cry:
I would take the piss out of you lot but Mother Nature's beaten me to it  :pok:
Reply #22 on: May 27, 2009, 08:17:08 PM
Flash
  • Guest
Reply #23 on: May 27, 2009, 08:28:12 PM
Reply #24 on: May 27, 2009, 08:47:50 PM
Can I, I do. Shall I, I won't. :P
Reply #25 on: May 27, 2009, 11:19:14 PM
he he he....
You go Flash, go forth and strap make  :tu:
