Great way to carry a SAK
Zack · 37 · 3532
spam Offline Zack
on: June 05, 2009, 06:27:44 PM
This is probably old news to most of you guys, but its new to me.  I picked up a small Nite Ize S-biner last night, and its perfect ofr attaching to the keyring, and then you just clip it to the inside of your pants pocket.  Now it hangs from the pocket like a tactical folder and keeps it from banging around with the other stuff in my pocket.  I am carry a 4-layer Wenger which I would not usually because of the heft, but I can barely tell its there.
Offline Precise
  • I can haz multitoolz nowz?
Re: Great way to carry a SAK
Reply #1 on: June 05, 2009, 07:02:46 PM
Nifty! It sounds useful, but I have no idea what those are. Could you take some pics?
spam Offline Zack
Reply #2 on: June 05, 2009, 07:35:55 PM
Here is a pic of what they look like.  I use the smallest one (the #2)
Offline cgk
Reply #3 on: June 05, 2009, 10:54:16 PM
I just found out y local pet food store carries them (why in a pet food store I will never know).  I bought two little ones, they will not be my last.
mx Offline Sidhartha
  • Hecho en México
Reply #4 on: June 05, 2009, 11:06:36 PM
a good way to carry small ones arround the neck  :tu:
custom swiss army knives
Offline cgk
Reply #5 on: June 05, 2009, 11:11:19 PM
Never thought of that, good idea.
Flash
  • Guest
Reply #6 on: June 05, 2009, 11:16:28 PM
Dudes and dudesses,
A word of warning....I have lost stuff when this clip unclipped itself from my belt.
I checked with another forum (don't shoot me :P) and LOADS of people have had the same problem.
It seems great at first but PLEASE exercise caution with this clip.
Mine is now on a landfill somewhere  ::)
Offline jock1
Reply #7 on: June 05, 2009, 11:34:40 PM
Thanks Flash
I had given thought to this clip for my duty belt but will try elsewhere
Cheers
wales Offline rp252
Reply #8 on: June 06, 2009, 12:23:21 AM
I've heard similar things about the S-biner.  The clips need to be stiffer apparently.  I've not got one so I can't say, but be careful if you use one :)
gb Offline Craig
Reply #9 on: June 06, 2009, 12:45:41 AM
Dudes and dudesses,
Thanks for the heads up. You may well have saved me from the trauma of losing a tool :tu:
Prone to daydreaming.
Reply #10 on: June 06, 2009, 12:58:09 AM
Dudes and dudesses,
I was going to mention the same thing.
I tried them for a bit and they kept coming off so now I have got rid of them. I won't be using them again.
Offline jojobos
Reply #11 on: June 06, 2009, 01:03:47 AM
+1 I wish the spring tension is little stronger. But works great when hanging inside the pocket as Zack mentioned.
spam Offline John
  • Avatar removed by request
Reply #12 on: June 06, 2009, 01:04:25 AM
Hi guys I don't carry mine this way but! I thought it good to post this :tu:
It's a inova SS clip which I have found to be secure in use  :D
A better pic without the silly metal clip  :ahhh
Just throwing some ideas out there,if you have a hook in ya SAK try this.
Not for everyone I know but! it works ok  :tu:
« Last Edit: June 06, 2009, 01:44:56 AM by JohnM »
Reply #13 on: June 06, 2009, 10:45:23 AM
Dudes and dudesses,
Me too, the spring pressure really is a bit on the weak side :-\
us Offline Swiss Man
  • WIFE APPROVED
Reply #14 on: June 06, 2009, 04:11:51 PM
I have one of these and I really like it,
BUT the other day I noticed that my pocket was heavy that is when I noticed that the snap broke and all my stuff was at the bottom of my pocket.
So if you wear one be sure to pocket your goodies.
To be fair though I bent the snap the other day and straightened it with my Spirit so that could have had something to do with the failure.
spam Offline John
Reply #15 on: June 06, 2009, 04:36:11 PM
Maybe you need one of these http://www.7dayshop.com/catalog/product_info.php?cPath=777_8&products_id=101887  :tu:
« Last Edit: June 06, 2009, 04:40:05 PM by JohnM »
scotland Offline Nikos
  • Why is it doing that?
Reply #16 on: June 06, 2009, 04:43:24 PM
I've had great success with a variation of Stormdrane's paracord keyper. :tu:
Reply #17 on: June 06, 2009, 06:37:34 PM
I use a small s-biner but it does hang in t my pocket so would hopefully not cause me to lose anything. I have heard they are unreliable too but they are such a great idea  ???
Reply #18 on: June 06, 2009, 06:38:52 PM
They just need to beef up the spring tension imo :)
Reply #19 on: June 06, 2009, 08:23:48 PM
Any info on the Nextorch variant?
wales Offline rp252
Reply #20 on: June 06, 2009, 09:02:01 PM
Not currently, but I was going to grab a few with my next heinnie order (provided they do not put the price up).  I'll let you know then.
gp Offline Nightshade
Reply #21 on: June 06, 2009, 10:17:03 PM
 I've been using this arrangement for a few months and really like it. It clips inside of the pocket material. It's really secure and low key. Berkeley Point SS clip and SS fishing tackle swivel.  :) Please forgive the poor quality photographer :-[
« Last Edit: June 06, 2009, 10:19:38 PM by Nightshade »
Reply #22 on: June 06, 2009, 10:31:23 PM
I was using something similar to this idea to carry my X-Tract. It worked quite well; the tool remained in the pocket, didn't dangle too much, was ultra-low-key and very fast to take it out and use. It provided no security when running/jumping/tumbling though. I also used the biner part to carry my skeletool, with the same pros and cons of the first solution. If your average day includes sitting (very comfy couches excluded) and walking, the hook/biner carry method is ok. If you anticipate any more vigorous encounters, I'd suggest going with a sheath, pocket-in-pocket, or sturdy pocket clip.
gb Offline Craig
Reply #23 on: June 06, 2009, 11:39:28 PM
I use a plastic trigger hook, like this one, except I use cord instead of curly wire.
http://tbn2.google.com/images?q=tbn:0PdOWE74VM2FmM:http://www.enforce-logic.co.uk/kr10.jpg
 I got the hook off a sunglasses case. It works well and the plastic is less likely to scratch scales than metal would be.
Reply #24 on: June 07, 2009, 12:06:31 AM
Wow.. I haven't seen this curly wire since the 80'...(neon colours)  :o :D :D
Offline I'm Still Bison
Reply #25 on: June 07, 2009, 03:50:53 AM
I had thought the S-biner was the solution to my keyring carry.The problem was,that the keyring stayed securely in place on it's end of the biner,but the Fenix LD 01 and Manager at the other end kept coming off.The final straw was when I lost my Manager,and nowhere in sight. S-biner now forgotten and put away,and a Mini-Champ rides on my new arrangement until I score another Manager.
I
Offline gadgetman7
Reply #26 on: June 07, 2009, 03:52:52 PM
I use this:
http://www.uncle-mikes.com/products/inside_the_pocket_holsters.html
It keeps everything vertical and smooths out the lines so my pockets don't bulge. It will hold a MT and flashlight. I typically carry either a Skeletool or Spirit and a AA or 1 CR123 flashlight in it with the multitool.
I don't know if these are available in the UK but they cost about $10 here.
Reply #27 on: June 07, 2009, 03:56:32 PM
I use this:
Never seen them over here I'm affraid, but then we've not be aloud pistol's for a long time, so there'd be no market for them :-\
Offline gadgetman7
Reply #28 on: June 07, 2009, 04:00:12 PM
Uncle Mikes would probably ship it to you. I wonder how much the postage would be. I wonder if one of the large pocket protectors would work. I'll have to try that.
Reply #29 on: June 07, 2009, 04:00:45 PM
Surely the Nextorch one (the smaller one) is a total copyright infringement on the S-biner?!  :think:
Total Receipts: $122.41
PayPal Fees: $6.85
Net Balance: $115.56
Below Goal: $184.44
39%
