Woohoo, Victorinox new soldier
jzmtl · 44 · 4048
ca Offline jzmtl
on: June 10, 2009, 10:42:04 PM
Just picked it up today.  :mail: So now the question is do I use it or keep it new. :D
Some thoughts on it.
*It's definitely high quality, everything is smooth.
*The dark green portion of the scale is the so called rubberized portion, but unless I run my fingernail across it I can't tell, it's not any more grippy than hard plastic portion.
*Scale is much more compact than Wenger's version, 3mm per scale as oppose to 8mm of wenger at widest. To be honest I don't find wenger's contoured scale any more ergonomic than flat scale, and I would rather have flat to be more compact. IMO this is one thing Vic got right over Wenger, the end result is a lot more compact (thinner scale, no additional aluminum liner next to the steel locking liner)
*Blade has no point, it's basically rounded tip at the factory. Duno why they did it but I would prefer to have a sharp point on my blades.
*Liner lock is definitely lefty, not righty friendly. I can do it with right hand but it takes a bit of struggle and I wouldn't trust myself doing it under stress, and it's probably not very safe either. I don't know why they did it this way, because I see absolutely no physical limitation to flip things around.
*No jimping on spine of blade, I'd like to see some for traction.
*On the plus side, it works great for left hand, even though I'm right handed. Also even thou the blade is in the center slot, it can be opened easily with either hand.
*The etching on blade is not laser etched, it's raised above blade surface, don't know what it is but doesn't look like paint. I hope it's durable, because when open the blade with left hand it rubs agains the steel liner.
*Of course there is always problem with limited edition, do I use it or keep it pristine?  :(
« Last Edit: June 10, 2009, 10:52:39 PM by jzmtl »
Re: Woohoo, Vic new soldier
Reply #1 on: June 10, 2009, 10:42:50 PM
Use it dude!!!
hn Offline cliosguy
  • no nacimos con miedo...
Reply #2 on: June 10, 2009, 10:44:43 PM
congrats!! :tu:
i ve carried mine, but im thinking maybe in the future to get me a 09 one and save the 08 for the collection :)
A
it Offline sardauker
  • Just arrived
Reply #3 on: June 10, 2009, 10:47:44 PM
keep it pristine- it would be my shelf king :/
Reply #4 on: June 10, 2009, 10:49:39 PM
Don't listen to them!  ::) :D
Print off your picture and stick it on the wall if you want to see a pristine one.  Then go and use it for what it was made for and enjoy it.  :D
ca Offline jzmtl
Reply #5 on: June 10, 2009, 10:50:56 PM
There is also the problem of lefty liner lock if I were to use it thou.
By the way it can be spyder dropped open.  :D
Reply #6 on: June 10, 2009, 10:53:19 PM
You quickly get used to it.
ca Offline jzmtl
Re: Woohoo, Victorinox new soldier
Reply #7 on: June 10, 2009, 10:58:35 PM
Yeah, but I'd then get confused with my right liner locks.  :P
Is this really exactly the same as swiss army issue? Because on the liner it's stamped "press" in English, not German or French.  :D
  • Just arrived
Reply #8 on: June 10, 2009, 10:59:20 PM
buy another and use that! :D
ca Offline jzmtl
Reply #9 on: June 10, 2009, 11:01:45 PM
Woud like to, but
um Offline Mr. Whippy
Reply #10 on: June 10, 2009, 11:02:53 PM
+1
Why get a limited edition to work over?  Just get a run of the mill for that.  It would be like getting a proof set of coins and popping it open to buy a pack of gum.
gb Offline Craig
Reply #11 on: June 10, 2009, 11:25:44 PM
If it was mine, I'd use it, but I'd be very careful :)
Prone to daydreaming.
us Offline Pacu
Reply #12 on: June 10, 2009, 11:32:36 PM
+1
x2
It would be like buying a cat and feeding it dog chow. ::)
:like:    :MTO:
Reply #13 on: June 10, 2009, 11:35:14 PM
Another way of looking at it is that it's like buying a car and not driving it or buying a tool and not using it  ;) :D
hn Offline cliosguy
Reply #14 on: June 10, 2009, 11:37:51 PM
:D :D
A
Reply #15 on: June 10, 2009, 11:42:49 PM
Another way of looking at it is that it's like buying #1 of a limited edition Aston Martin and using it to haul garbage to the dump.  ;) :D
fixt
Reply #16 on: June 10, 2009, 11:43:33 PM
LOL  :D
ca Offline jzmtl
Reply #17 on: June 11, 2009, 12:02:07 AM
fixt
If I had an aston martin I'd actually do that, since it's losing value whether used or not.  :P
us Offline BIG-TARGET
Reply #18 on: June 11, 2009, 12:41:09 AM
The Vic OH series, and the Wenger "OH"Ranger series BEG TO BE USED!!! :tu:
Reply #19 on: June 11, 2009, 12:50:57 AM
fixt
Trust me, the resale value will be higher if the engine hasn't had the guts thrashed out of it and it doesn't smell of garbage ;)
One day, I will own an Aston. I really will  :)
us Offline bren10man
Reply #20 on: June 11, 2009, 12:58:21 AM
I solved that very delima myself: I have BOTH- a 2008 Limited Edition, and a 2009-made that is my EDC in my rucksack.  Same goes for the final Alox run, one to use if I want, the other with the rest of the collector knives on the shelf.
Get both, will cure the "guilt trip".
MOLON LABE!
ca Offline jzmtl
Reply #21 on: June 11, 2009, 02:03:11 AM
fixt
If I had the spare cash for one I don't think I'd care about resale value.  :)
Offline AndyTiedye
  • Ride the Music
Reply #22 on: June 11, 2009, 06:41:33 AM
They also say "Swiss Made" in English.
If they printed it in German or French,  they'd have to print it in both, wouldn't they?
R
ca Offline jzmtl
Reply #23 on: June 11, 2009, 06:47:51 AM
Yes, but "Swiss Made" is for international market, while this is for the Swiss military where English is not the official language.
I think I've stayed in Quebec for too long.  :(
Reply #24 on: June 11, 2009, 06:55:31 AM
It'll probably be a good long while before it's truly valuble, so using it for light duties would be ok imo :)
  • Just arrived
Reply #25 on: June 11, 2009, 07:06:57 AM
have you seen the "unbreakable" movie?
remember about hanging the first number of I don't remember which comic in a kid's room? :D
Reply #26 on: June 11, 2009, 11:40:34 AM
fixt
So you'd quite happily use an Aston for garbage duty and not worry about the future value, yet you ask us whether you should use a Vic soldier or not.  :think: :D
ca Offline jzmtl
Reply #27 on: June 11, 2009, 08:05:03 PM
Key words being If I had the spare cash.  :P
ca Offline jzmtl
Reply #28 on: June 12, 2009, 06:32:21 AM
Well, problem solved.  ::) A week ago I had a hard time deciding which one to get and thinking there is no way I'd get both, but here I am, keeping the soldier NIB and going to EDC the OHT.
« Last Edit: June 12, 2009, 06:36:35 AM by jzmtl »
hn Offline cliosguy
Reply #29 on: June 12, 2009, 06:37:11 AM
Congrats :tu:
A
Total Receipts: $122.41
PayPal Fees: $6.85
Net Balance: $115.56
Below Goal: $184.44
39%
