Blackbeard · 5839 · 504105
us Offline prime77
Reply #120 on: August 07, 2009, 05:21:08 AM
I didn't want to rummage around the shed tonight for one of those wheel thingys you use to put a window screen in the metal frame. So I used the back of the can opener of my LM Pulse. Worked like a charm.
spam Offline John
  • Avatar removed by request
Reply #121 on: August 07, 2009, 07:57:35 PM
Stripping some flex today with my CT 41 it works great for flex,coax or twin and earth  :tu: using the main blade,small one open and out of the way.all you do is rotate the cable you want to strip toward the tang,use only the blades spring pressure for this purpose,with practice you can do away with some other wire strippers that can either not be at hand or through experience you've loaned it out and it's GONE  :ahhh
gb Offline Craig
Reply #122 on: August 07, 2009, 07:59:22 PM
Nice tip, John :tu:
Prone to daydreaming.
hn Offline cliosguy
  • no nacimos con miedo...
Reply #123 on: August 07, 2009, 08:11:10 PM
posted in other place, but i guess is better here:
crunch as a multi size bit adapter:
10/10 :tu:
A
gb Offline Screwtape
  • I am the Toast King!!
Reply #124 on: August 07, 2009, 09:13:41 PM
igniter for the grill died today so the spirit was put to good use as a nice long handle for poking a match in, worked a treat   :tu:
10/10
"Hello! I am the Toast King and I rule over the Moon!"
spam Offline John
Reply #125 on: August 07, 2009, 09:44:07 PM
10/10
Did you not think of the potassium + glycerin tea bags  :D
Reply #126 on: August 07, 2009, 11:06:58 PM
10/10 :tu:
Nice... Overkill, but still nice..  :D :D
Reply #127 on: August 07, 2009, 11:43:17 PM
10/10 :tu:
OK, being picky here as I am in a picky mood.  :P
How can you say that is 10/10?  Not exactly the easiest to use is it?  A dedicated extra comfy to use bit driver would be my 10/10 but that?
I've finished being picky now.  :D
Reply #128 on: August 07, 2009, 11:45:22 PM
Good shift at work then Ben? :D
Reply #129 on: August 07, 2009, 11:48:01 PM
Reply #130 on: August 07, 2009, 11:48:26 PM
No!  :D
Thought not :D
Would you like to share with the group ??? :D
hn Offline cliosguy
Reply #131 on: August 08, 2009, 12:00:44 AM
10/10 :tu:
thats the problem it solved...i didnt have a "dedicated extra comfy" :P
A
um Offline Mr. Whippy
Reply #132 on: August 10, 2009, 07:32:34 PM
Resurrection:
So, on Fri (I think) I created the OH Locksmith.  Sat morning, Mrs. Whippy and I began work demolishing a wall damaged by water and replacing it with 2 windows and reframing.  The damage went up to the roof line.  Finished Sunday evening.
Used the OH Locksmith extensively as a keyhole saw, to file through nails before snapping them off with a hammer in the old exterior sheathing and the mainblade for trimming the plastic flashing around the new windows.  Ended up with a few scars on the scales, and needed to sharpen the main blade, but overall, I'd rate it 8/10 as utility tool.
BTW, I used a Husky box cutter to score drywall, rather than the mainblade.  Just seemed to be the right way to go.
Reply #133 on: August 10, 2009, 07:47:02 PM
Good call on not using the SAK for the drywall, that stuff really dulls any knife in seconds.
Offline SingleTool
Reply #134 on: August 12, 2009, 10:08:48 PM
Cut the tip off of a hypodermic needle.   8)
Reply #135 on: August 12, 2009, 10:30:56 PM
Used the Vic Spirit to strip down a Mac 700 Spot to day as the power modual didn't seem to be working.  The ratched set was perfect not only by having all the torx and allen heads necessary but also being able to get into  all the awkward bolts where a long handle driver wouldn't reach  :tu:
Spirit 10/10
Unfortunately the power module was a bit further gone than I expected as when I swapped it into a different unit to prove the fault it exploded,  :-\ violently causing an as yet unknow amount of damage that I will be investigating tomorrow  :-X
My skills 1/10   :-[
hn Offline cliosguy
Reply #136 on: August 12, 2009, 11:39:56 PM
crossgrip flat driver as a mini prybar to open a wall faceplate 10/10 :D
A
Reply #137 on: August 12, 2009, 11:57:26 PM
Spirit 10/10
My skills 1/10   :-[
That's a funky looking bit of kit.  I think if I came across it above a darkened auditorium I'd ask if it wanted to be taken to my leader  :ahhh ;)
Reply #138 on: August 13, 2009, 12:08:26 AM
Spirit 10/10
Unfortunately the power module was a bit further gone than I expected as when I swapped it into a different unit to prove the fault it exploded,  :-\ violently causing an as yet unknown amount of damage that I will be investigating tomorrow  :-X
My skills 1/10   :-[
I hope it's not as bad as it sounds. :-\
Offline sappyg
Reply #139 on: August 13, 2009, 12:12:45 AM
nothing flashy but i used the spirit PE blade to cut the end off a tube of fire caulk to seal an electrical penetration to pass a rough inspection.
later i used the SE blade to shorten the disconnect rope for 2 garage doors on another home. both blades did very well. i am not carring a SAK lately to force myself to use the spirit wherever possible. no complaints so far.
i
Reply #140 on: August 13, 2009, 12:13:16 AM
You should see the bits all spread out, I'll try and get a pic before a reassemble it tomorrow
I'm an optimist about the 2 year warranty  ;) hope it covers idiots with multis  :think:
Reply #141 on: August 13, 2009, 10:12:37 PM
I am doing a lot of decorating ATM and moving stuff around.  The Fuse has been pushed pretty hard, but is still going strong.  :tu:
us Offline HBlaine
  • It does WHAT??
Reply #142 on: August 14, 2009, 12:03:28 AM
Used the Wave to finish tearing up crates, etc., to feed the nice big fire I had going in the improvised burn cage I put together.  (Another Wave project.)
Alas, no pictures.  I didn't have time, as I didn't have the help that I thought I would....   :rant:
As the man said, "...You have to do everything yourself...  It's a funny world we live in..."
Nothing says extraterrestrial like...
us Offline Mike 56
Reply #143 on: August 14, 2009, 05:05:26 AM
Went to the range to shoot my  black powder rifle at today. Used my Spartan to cut my shooting patches at the muzzle did a great job. Had a good time. Getting ready to go night fishing for Catfish right now. Hopefully i will have some fish to clean. I love catfish and eggs in the morning.
Mike
Mike
Offline Leatherman123
Reply #144 on: August 14, 2009, 05:31:52 AM
What do you use for bait?
B
Reply #145 on: August 14, 2009, 06:13:48 AM
pocket power plier
I havent been catfishing in a long time. I use to like fishing for big flat heads. Its like hooking on to a freight train. I didnt catch a big one very often but it sure was exciting when it happened. Mike 56 hope you catch some good ones.
Offline ratslash7
Reply #146 on: August 14, 2009, 12:21:11 PM
Mike
Next time could you shoot at Tomorrow?. It's always scarier than Today. :ahhh
Dave
A
us Offline Mike 56
Reply #147 on: August 14, 2009, 03:48:46 PM
pocket power plier
Out here on the Califorina Delta Catfish will bite on lots of stuff Anchove, Sardines, fresh water clams last night we used night crawers and checken liver cought fish on both. We couhgt ten pan sized Channelcats. It was a new spot we were trying out the fishing wasn't the best  the fish were small but i have to atmit they were good eating size. We had a good time.
Mike
« Last Edit: August 14, 2009, 03:52:58 PM by Mike 56 »
Mike
us Offline HBlaine
  • It does WHAT??
Reply #148 on: August 14, 2009, 11:17:00 PM
Used the SwissTool to help with some basic breakdown and clean-up work.  (I'm setting up another nice "Let's burn everything!" event.   >:D)
Just used my Wenger Traveller to do some surgery on an apple for dessert this evening.  I think it (or one of its SAK brethren) might just do some dissection work on a peach later for the evening snack...   :D
Offline sappyg
Reply #149 on: August 14, 2009, 11:40:51 PM
the vic spirit repaired a peice of damaged silt fence... pulled out a staple so i could move a section of 110 wire wiring plus cut and stripped wire to replace a 4 foot flourescent light in a garage.
i
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
