Blackbeard · 5824 · 437054
us Offline Yadda
Reply #5580 on: February 19, 2018, 12:13:34 AM
I used my Style CS scissors to cut the exposed piece of plastic from a plastic wall anchor.
england Offline Kev D
Reply #5581 on: May 06, 2018, 05:09:12 PM
Various gardening duties for the surge.  The vic saw is better than the standard leatherman saw for cutting bamboo canes
us Offline ToolJoe
Reply #5582 on: May 08, 2018, 04:47:23 AM
I used the butter blade on my Spirit to cut some plastic today at work. Also used my Knipex plier wrench to attach bolts for a license plate. Tonight, I used the can opener on my Spirit to open two cans for dinner tonight.
Reply #5583 on: May 26, 2018, 07:46:55 PM
Sak pin and tweezers to the rescue to remove a stubborn splinter.
It's amazing how such a small piece of wood can feel so big
us Offline HarleyXJGuy
Reply #5584 on: May 26, 2018, 10:27:27 PM
Took everything down off the walls and filled the holes and removed the wall hanging hardware.
Used my SC to dig broken drywall and paint out of the holes, remove screws and mix drywall mud with the fish scaler.
Cut tape and gave moral suppprt while packing the pictures and stuff into boxes.
Reply #5585 on: May 27, 2018, 01:44:22 AM
Wife was trying to open a pop top can of vegetables abd the pull ring came off.
She was like dang how will I open this now?
Swiss Champ flathead driver/prybar to the rescue.
Reply #5586 on: May 27, 2018, 01:46:28 AM
Nice !     :like:
You moving  Harley ?
Reply #5587 on: May 27, 2018, 03:52:19 AM
Nice !     :like:
You moving  Harley ?
Yeah just 40 minutes away out in the country.
When I retired from the Army we decided to rent while we got settled back home in Michigan.
Reply #5588 on: May 31, 2018, 12:35:59 AM
Stick a Bosch "Speed for Wood" (coarse pruning type teeth) jigsaw blade in the holder--it will zip through wood in no time. I prefer using that to the saw that comes with the Surge.
At the grocery store today, while going to get a second shopping cart I noticed a lady was having trouble separating two shopping carts.   First of all, I tried pulling them apart by hand. That didn't work.  Finally, I found a part of the bottom basket that had been crushed and bent against the bottom basket of the other cart (I'm guessing both carts together had hit something with some force), pinning the two carts together. Using the "screwdriver" (really, it's more of a pry bar) on the Duluth DH16 Handiman, I got the two carts apart by prying one of the damaged pieces up and pulling the front cart out.
« Last Edit: May 31, 2018, 12:38:38 AM by cody6268 »
us Offline Noa Isumi
Reply #5589 on: May 31, 2018, 02:35:49 AM
Use the serrated blade of the Trekker to clip excess husk and silk off the tops of some corn before putting them in the coals to roast.
se Offline MickeS
Reply #5591 on: July 03, 2018, 09:43:58 PM
Hi everybody! Used the Micra and took apart a crappy kitchen sharpener. Used the small diamond files inside to sharpen my folded knife by hand and reassembled the sharpener again.
Sent from my SM-G965F using Tapatalk
se Offline MickeS
Reply #5592 on: July 04, 2018, 04:38:57 PM
Ok. Don't laugh. I know the Surge isn't the right tool for this but its brand new and I've been roaming the house looking for something to fix. Found a malfunctioning doorlock. There was a broken spring (right word?) inside. Oild and cleaned it up. Put it together and it's fine!
se Offline kottskrapa
Reply #5593 on: July 04, 2018, 05:29:59 PM
Ok. Don't laugh. I know the Surge isn't the right tool for this but its brand new and I've been roaming the house looking for something to fix. Found a malfunctioning doorlock. There was a broken spring (right word?) inside. Oild and cleaned it up. Put it together and it's fine! (Image removed from quote.)(Image removed from quote.)
If you fixed it, it was the right tool
Reply #5594 on: July 10, 2018, 05:38:59 PM
Corkscrew got to pry the lid of a jar.
gb Offline Jaypeebee
Reply #5595 on: July 15, 2018, 03:03:08 PM
Need a little help to open a valve!  :tu:
* 20180715_100102-1209x1612.jpg (Filesize: 236.51 KB)
au Offline gregozedobe
Reply #5596 on: July 15, 2018, 05:08:26 PM
Lookin' good.    :tu:    When you really need locking pliers nothing else will do :)
Reply #5597 on: July 15, 2018, 05:42:13 PM
So very true  :tu:
us Offline Captain Hook
  • Don't read this......You rebel you ;)
Reply #5598 on: July 16, 2018, 08:54:12 PM
gonna have to remember that trick in the future. Nice one reamer punch  :tu:
~Formerly _MattGyver_ ~
Reply #5599 on: August 11, 2018, 10:05:26 AM
Reassembled my bike.   :multi:   :multi:
us Offline Mercury
Reply #5600 on: August 13, 2018, 07:17:46 PM
I was tearing out a ceiling and putting in a large patch the other day, and there was a vent fan/light combo in the middle of it(bathroom).  I had to use my Rebar's flat head driver to pry the fan shroud into the hole into the new piece I had cut.  That Rebar saw a lot of use that day.  I also had to use the saw to trim some sheetrock to fit, and realized that there really isn't a substitute for a good sharp keyhole saw...
se Offline RF52
Reply #5601 on: August 13, 2018, 10:02:39 PM
Skeletool to put up curtain hangers after painting the bedroom
us Offline Blackbeard
  • One Day Closer To Death
Reply #5602 on: January 03, 2019, 10:59:58 AM
 :whistle:
it Offline SirVicaLot
Reply #5603 on: February 16, 2019, 11:14:42 PM
Gerber Suspension to free some new drill bits from the plastic of doom  >:D
* 20190214_114101small.jpg (Filesize: 103.82 KB)
nl Offline LanWolf
  • */ Just A Byte */
Reply #5604 on: February 18, 2019, 09:28:22 AM
Have been busy a whike, but had Some time for my ham radio hobby yesterday, and used my surge a lot while adjusting an Antenna.
Reply #5605 on: February 18, 2019, 03:08:35 PM
Good usage! Call me stupid,  but no idea what a ham radio is.  :facepalm: Care to explain?  :popcorn:
nl Offline LanWolf
  • */ Just A Byte */
Reply #5606 on: February 18, 2019, 03:25:17 PM
Very short description:
Ham radio or Amateur Radio is mainly making radio contacts all over the world. Can be done in voice, morse (cw) or all kind if digital modes.
Many apspects involved, i especially like making and tuning Antenna systems, and use them to get as long distance contacts as possible.  For example, from the netherlands where i live, to a friend in Brazil. (Making use of shortwave bands and radios)
It is like make phone calls, but without the lines between.
Reply #5607 on: February 18, 2019, 03:32:05 PM
That is pretty cool! I just wonder, do you have to bounce off the radio signals over a relay? Because earth‘s curvature should prevent a direct connection between Netherlands and Brazil, right?  :think:
nl Offline LanWolf
  • */ Just A Byte */
Reply #5608 on: February 18, 2019, 03:50:05 PM
No, for shortwave, that is not done by a relay, it is a direct contact. The Antenna radiation angle will send the signal into the ionosphere, where it will bounce back down again.
For local contacts on 144-146mhz there are many relays here, but that is for short distance like 50km or so
Reply #5609 on: February 18, 2019, 03:53:02 PM
Very interesting, thanks for providing some details  :tu: :like:
