Blackbeard · 5839 · 485098
fi Offline Pilotsupergrip
Reply #5790 on: August 31, 2023, 06:08:23 AM
The northern parts of Alaska and Canada are the same way.
What Squirt do you have? They're great little tools! :tu:
It a PS4. Great for small tasks. I like the toolset and the sturdy feel. I think I bought it during a summer holiday trip from a jewelry store we visited. Changed the batteries to a watch I think. And I saw the Squirt there on a display somewhat underpriced. Didn't buy it at once when I saw it but had to go back to the store to buy it after few hours. Lucky I did! Got my brand new Micra in a same way from a flea market few years later :D
The Squirt seems to get a little more pocket time than my Micra. Both are great tools though, just for different purposes. People don't get amazed when you pull one out from your pockets in an office so that's a bonus.
Got an action pic of Squirt from yesterday also. Had a charger that had a loose led light that I had to glue back to place and the charging pins were bent slightly. The philips head works well even with the small electronics screws. At least if they are not sunk deep.
Lähetetty minun SM-A426B laitteesta Tapatalkilla
Curl, Surge, OHT, Crunch, Micra, Squirt PS4, Style CS, Huntsman, Spartan, Classic SD, Armbar Slim Cut
us Online Farmer X
Reply #5791 on: August 31, 2023, 06:11:38 AM
us Offline Adam5
Reply #5792 on: September 02, 2023, 03:17:39 AM
Cut some drywall, tightened a recessed nut, tightened a screw, filed down some plastic, and pried out a plastic part from a metal bracket  :tu:
Reply #5793 on: September 02, 2023, 03:44:11 AM
It's hard to work on recessed nuts with LMs. Do you have a way to use sockets? Or did you manage to do that just with the pliers?
Seems like your LM got some real use today! Is that btw a Rebar or ST? Hard to tell from the picture as there is no way to compare the size :D
Reply #5794 on: September 09, 2023, 07:09:54 PM
Used the Curl to put a new wick for my old zippo. Used the pliers to pull out the wick and cotton balls and awl to push them back in. Got to use the flathead also on the flint spring screw.
Reply #5795 on: September 12, 2023, 06:19:27 PM
Today Curl helped to unscrew our two tower fans for thorough cleaning so we could take these to storage as the weather is not that hot anymore.
Reply #5796 on: September 19, 2023, 07:09:39 AM
Used today the Curl diamond file to sharpen the trauma shears of my IFAK. The blades were in a bad shape from factory. Wish I got more higher quality shears like Piranhas or even LM Raptor but after sharpening these cheap ones might do just fine. Im not expecting any emergency use for these but I like trauma shears for my IFAK more than the smaller nail scissors as these produce more cutting force and thus are more versatile. You never know. Might have to cut my pants the next time in the woods. :)
pr Offline Juan el Boricua
Reply #5797 on: September 21, 2023, 10:11:25 PM
Spirit XC; quartering guavas.  [ You are not allowed to view this attachment ]
us Online Farmer X
Reply #5798 on: September 24, 2023, 03:30:45 AM
gb Offline Damsel
  • Damsel in this dress
Reply #5799 on: December 16, 2023, 10:23:58 PM
I used my multitool to pry off the knobs on my cooker hob for cleaning because they were rather stiff. Sorry I didn't take a photo, I was in the middle of cooking and didn't have the foresight to switch it to "off" before I took off the knob. I had to scramble to find the right position before I burned my bolognese!
When did you last clean under your knob? (oo-err)
Danielle.
« Last Edit: December 16, 2023, 10:50:08 PM by Damsel »
:angel: Sugar, spice and everything nice.  :angel:
us Offline David Bowen
  • Multitool Enthusiast
  • Site Manager
Reply #5800 on: December 17, 2023, 02:25:48 AM
Use the Arc to assemble a rocking chair. Pliers helped twist an Allen wrench I couldn't get enough torque on, and screwdriver to put the rocking portion on
Sent from my SM-G996U using Tapatalk
fi Offline old Lefty
Reply #5801 on: December 23, 2023, 11:37:58 AM
Mother Nature tried to stop access to mailbox with ice and slush to the lock. Enter SwissTool:
by this axe I rule
ua Offline in_sympathy
Reply #5802 on: February 06, 2024, 08:16:14 PM
Tightened a loose nut with a Spirit. Also used a package opener once again - truly the most used tool for me
Reply #5803 on: February 11, 2024, 02:37:29 PM
Wife cooked some pancakes this morning, so I opened a can of homemade raspberry jam
Love using a beefy Spirit cap lifter for that job - works best in my opinion
Magic Bus
  • Guest
Reply #5804 on: February 11, 2024, 02:57:41 PM
Strat fettling  :multi:
Magic Bus
  • Guest
Reply #5805 on: February 11, 2024, 03:06:07 PM
Love a Swisstool  :multi:
Reply #5806 on: February 11, 2024, 04:05:28 PM
That is a nice Strat you have there
Magic Bus
  • Guest
Reply #5807 on: February 11, 2024, 04:14:30 PM
Thanks mate  :tu:
us Offline Murphy Slaw
Reply #5808 on: February 11, 2024, 04:41:30 PM
I "MacGyvered" this Snark tuner to live on for another day.
Magic Bus
  • Guest
Reply #5809 on: February 11, 2024, 04:46:36 PM
Well done Murphy  :tu: and extra points for the Paratool.
Magic Bus
  • Guest
Reply #5810 on: February 27, 2024, 10:56:31 AM
Took the cover off an EP Booster to  have a play with the switches inside.
fi Offline customod
Reply #5811 on: March 17, 2024, 01:05:07 AM
So today I took the family to visit some friends at their small cabin. We were setting up to eat lunch and they brought some extra chairs out. The hostess was about to take one for herself that looked like it was about to fall apart.
I asked about it and offered to try to fix it really quickly and she said they hadn't brought any tools along. I smiled politely and assured her that it wasn't a problem.  :climber:
Turns out it just needed a few 4mm hex screws adjusted and then tightened down properly. Here's a pic of what I had on me to use.
Reply #5812 on: March 17, 2024, 01:41:47 PM
Yep.
Love it.
us Offline HarleyXJGuy
Reply #5813 on: March 17, 2024, 02:11:45 PM
Changing the base plates on some new magazines.
Reply #5814 on: March 17, 2024, 05:04:51 PM
Will those give you an extra round or two?
by this axe I rule
Offline Anthony R
Reply #5815 on: March 20, 2024, 08:22:16 PM
I used the Vic combo tool to peel some fruit  :tu:
Reply #5816 on: March 21, 2024, 12:27:48 AM
Well sorta.
The magazine is for a slightly larger version of my pistol.
The base plate you see on the magazine fills the gap that is created. For look and to prevent over insertion which can damage the magazine or weapon.
Forgot to add the normal capacity is 15 rounds but these are 17 rounds.
Reply #5817 on: March 22, 2024, 01:29:11 AM
Thankfully I had both of them in my EDC bag because I needed both the center drive and the dual force to fix an emergency brake on a mobility scooter that was defaulting to locked.  I was unsuccessful and will have to bring the scooter to a professional. :facepalm:  I didn't have enough hands to take a picture of the action so here's an older pic of the pair.
Reply #5818 on: March 23, 2024, 06:18:16 PM
Here is a photo to better illustrate how it fills the gap.
Reply #5819 on: March 23, 2024, 07:03:29 PM
Ok. Thanks. Seems flush fitting solution
Looks like it also gives a bit more lenght for grip if needed
by this axe I rule
November Goal: $300.00
Due Date: Nov 30
Total Receipts: $57.17
PayPal Fees: $3.47
Net Balance: $53.70
Below Goal: $246.30
18%
November Donations
