No sweat. Hopefully, Tim will be along shortly.
Let me be more specific. Would you say the new LED is significantly inferior to the Victorinox Microlight, or is it about the same?
Quote from: Rodion on July 10, 2009, 11:09:29 PMLet me be more specific. Would you say the new LED is significantly inferior to the Victorinox Microlight, or is it about the same?Microlight has a larger battery and is brighter. Depends on what you need. If a stand alone LED is ok then I would go with the Microlight. I find the new white LEDs in the 58mm to be quite good and sufficient for my needs.
No scale removal required. There is a tiny hole in the side, you push a paper clip into it and it opens a door on the other side of the scale and the battery slides out. You can then slide a new battery in and close the door.
