Chick digs scars!
We live and learn (at least that's the idea ). Is this a bad time to point out that the little Phillips found on the Vic Rambler etc works very well on those tiny heads? I hope the thumb heals quickly.
Ouch, hope no children were there so they don't learn bad knife habits Hope you heal up fast Maybe you should carry your cybertool around next time.
You think you were doing wrong? Try using the can openner as a hook....got my thumb cutted reeeeeeally deep :/ bleeding like a fountain I suposse some of us need to learn things the hard way
At least the blood won't attack the steel like it would on lesser tools Hope it heals quickly mate
I guess the lesson we should all take away from this is...Buy a cybertool and rambler and always keep it close by.
Quote from: One Lame Frog on July 13, 2009, 06:58:47 AMI guess the lesson we should all take away from this is...Buy a cybertool and rambler and always keep it close by. The lesson I've learned is to grab a few more sets of cheap jeweler's screwdrivers. One for the car, one for the rucksack, one for the briefcase.
Quote from: ringzero on July 13, 2009, 07:30:38 AMQuote from: One Lame Frog on July 13, 2009, 06:58:47 AMI guess the lesson we should all take away from this is...Buy a cybertool and rambler and always keep it close by. The lesson I've learned is to grab a few more sets of cheap jeweler's screwdrivers. One for the car, one for the rucksack, one for the briefcase.What kind of lesson is that? It doesn't feed a SAK addition or anything! Are you sure you're on the right site?
Quote from: cliosguy on July 13, 2009, 04:16:06 AMYou think you were doing wrong? Try using the can openner as a hook....got my thumb cutted reeeeeeally deep :/ bleeding like a fountain I suposse some of us need to learn things the hard way Please tell us what you were doing when you got cut - maybe it's something we can learn to avoid.I've never done it, but have heard people talk about using the can opener as a hook..
Quote from: ringzero on July 13, 2009, 06:48:32 AMQuote from: cliosguy on July 13, 2009, 04:16:06 AMYou think you were doing wrong? Try using the can openner as a hook....got my thumb cutted reeeeeeally deep :/ bleeding like a fountain I suposse some of us need to learn things the hard way Please tell us what you were doing when you got cut - maybe it's something we can learn to avoid.I've never done it, but have heard people talk about using the can opener as a hook..i was trying to get a recessed card of a SDH node, this require a hook but the spirit one couldnt reach the hole, so i try with the can opener holding the SDH node with my left hand and pulling slightly to the left, the can opener blade slip(because is not a hook ) and my left thumb wasnt hard enough to stop it so it went trough leaving behind a clean cut, i was amazed that i wasnt bleeding and it didnt hurt, but just a few sec and i was struggling to make it stop it was pretty deepi learned my lesson, definitively
I believe that the smallest size on the cybertools' driver would work for the tiny screws also.
Quote from: tcolling on July 14, 2009, 02:12:16 AMI believe that the smallest size on the cybertools' driver would work for the tiny screws also.... and now that I think of it, the Phillips driver on the combo tool on the minichamp / rambler etc would likely work also
Hey RZ, for future reference, next time try using the tweezers. I've used them to remove screws in glasses. I've used them for tiny flathead screws as well as for phillips screws. For the phillips, I obviously use the corner of the tweezers. Try it out. It takes a little bit of practice, getting a feel for the tolerances of the tweezers before they bend, but in an emergency, they'll work.And they'll save you a nasty cut.
The guys in Ibach really know their job, Victorinox blades are scary sharp when new! I´m always impressed when I get a new Victorinox. Cut myself with a factory new Rucksack once - dude, that was a deep cut!Btw: Cut myself with a Spyderco Native yesterday. I just sharpened it, so it was realy sharp too. Just wanted to rinse it after using it, when I used my fingers to clean a bit of dirt of the blade I removed a nice slice of skin of my finger too. Ouch!
