Clipdraw McGraw
us Offline felinevet
  • Banner Member
Clipdraw McGraw
on: August 06, 2009, 04:03:00 PM
We now carry the Clipdraw, a very cool do it yourself pocket clip application for SwissTools, Spirits and any other Multi, knife or semi-auto handgun. These are cool. http://felinevet.sosakonline.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=1177&category_id=cdcc3145eb52ad203acfcf1a1dd22070&option=com_phpshop&Itemid=1
* Clip Draw on Spirit Plus.jpg (Filesize: 40.7 KB)
* Clip Draw Kit.jpg (Filesize: 6.64 KB)
T
Re: Clipdraw McGraw
Reply #1 on: August 06, 2009, 04:10:11 PM
That's a bargain mate :tu:
Re: Clipdraw McGraw
Reply #2 on: August 06, 2009, 04:46:48 PM
Considering just how many folks seem to want a clip on their Spirit this should go down a storm. :tu:
um Offline Mr. Whippy
Re: Clipdraw McGraw
Reply #3 on: August 06, 2009, 04:52:57 PM
Anyone actually used this?  Does it really work?
Inquiring minds have a need!  :ahhh
Re: Clipdraw McGraw
Reply #4 on: August 06, 2009, 04:54:20 PM
http://www.sosakonline.com/index.php?option=com_content&task=view&id=472&Itemid=35
Our very own Silentio :tu:
ca Offline ufox9al
Re: Clipdraw McGraw
Reply #5 on: August 06, 2009, 04:54:41 PM
This month's SOSAK article: http://www.sosakonline.com/index.php?option=com_content&task=view&id=472&Itemid=35  ;)
Alexei
Re: Clipdraw McGraw
Reply #6 on: August 06, 2009, 05:07:04 PM
I wonder if you could trim the tape shorter so that it does not extend past the clip  :think: :think: It would look better but would you loose some sticking power :think: :think:
us Offline ducktapehero
Re: Clipdraw McGraw
Reply #7 on: August 07, 2009, 12:56:10 AM
I wonder if it would work on the full size Swisstool. They're not as smooth.
  • Banner Member
Re: Clipdraw McGraw
Reply #8 on: August 07, 2009, 02:01:04 AM
Absolutely.  :salute:
T
  • Banner Member
Re: Clipdraw McGraw
Reply #9 on: August 07, 2009, 03:37:56 AM
Just did a SwissTool. Also wanted to see if it would still fit in sheath... yep, nicely.
* SwissTool w Clipdraw.jpg (Filesize: 47.4 KB)
* SwissTool w Clipdraw1.jpg (Filesize: 47.61 KB)
* SwissTool w Clipdraw2.jpg (Filesize: 48.37 KB)
T
ca Offline jzmtl
Re: Clipdraw McGraw
Reply #10 on: August 07, 2009, 03:41:43 AM
Looks like you can cut 1/3 of the base plate and make a ramp at the bottom so it doesn't catch on anything.
Re: Clipdraw McGraw
Reply #11 on: August 07, 2009, 07:42:26 PM
I'm gonna bet that I buy one of these soon.
Re: Clipdraw McGraw
Reply #12 on: August 07, 2009, 07:48:23 PM
I'm gonna try it on the Spirit and if it goes well, I'm gonna see if it'll work with a Juice.  :ahhh
  • Banner Member
Re: Clipdraw McGraw
Reply #13 on: August 07, 2009, 07:56:50 PM
The backplate is 3" long so all you need is a smooth surface of at least 3".
T
scotland Offline Nikos
  • Why is it doing that?
Re: Clipdraw McGraw
Reply #14 on: August 07, 2009, 07:57:29 PM
I wonder if it would still work with the sticky part limited/cut to just what's under the screws or so... :-\
Re: Clipdraw McGraw
Reply #15 on: August 07, 2009, 08:05:29 PM
It looks like 1/4 inch or so could be removed from the backplate, true?
  • Banner Member
Re: Clipdraw McGraw
Reply #16 on: August 07, 2009, 08:10:59 PM
The sticky strip sticks out past the end about 1/8" or so. I just trimmed it off to flush with the backplate. Width wise it is barely visible but could be trimmed with a razor blade to eliminate any overlap.
T
Re: Clipdraw McGraw
Reply #17 on: August 07, 2009, 08:14:15 PM
Check your email.  ;)
Offline silentio
Re: Clipdraw McGraw
Reply #18 on: August 07, 2009, 08:22:36 PM
MY REVIEW BECAME A SOSAK ARTICLE!!!
I had no idea!! I'm so pleased!  :D :D :D
BTW, clip is holding fine. No signs of weakness and i've been using it every day :)
Sorry for gratuitous use of smileys, I'm beside myself  :D
Offline silentio
Re: Clipdraw McGraw
Reply #19 on: August 07, 2009, 08:28:50 PM
Also, just a point to note, the surface you paste the tape on doesn't have to be completely flat. As mentioned in the review, it will stick fine even if you run it over the rivet. I don't have a full Swisstool, but if the rivets are the same as the Spirit's, I'm sure you can do the same there.
And regarding the backplate, yes, it's longer than the clip itself. But I think that's so the tape gets more gripping surface. Those who have the means to cut the baseplate perhaps can try shortening it, though I think the total hold won't be as strong if you do.
Re: Clipdraw McGraw
Reply #20 on: August 07, 2009, 10:10:41 PM
Fame at last, eh mate :tu:
