If you check that link on BladeMatrix I think tehre were three, weren't there? Two different designs, one of which was available in Metric and Imperial versions?Or maybe I am hallucinating form not having enough beer in me...Def
but then you are getting a little mall-ninjaish, unless you have a reason for these kinds of things.
It's not advised to use a bladed kerambit in the foreward grip position either for the same reason.In fact, any self defense tools that you slide your fingers in may solidify your impact in one direction, but if moved laterally in the lightest, can cause you serious injury. Small bones in your hands and fingers are very fragile, and if forced to take a lateral impact, compounded by a relatily thing hunk of metal or plastic can easily cause irreperable damage. The Kerambit is more or less stable in the grip because it is supported on both sides by the thumb and forefinger, and also by the other fingers and the palm of your hand. However, if you were to strike something in such a way as to jar the majority of your fingers loose, it's entirely possible that you could injure yourself even with that. Def
OT but are you a serenity / firefly fan Micky? Reason I ask is because of your sig, that's the song used in the opening credits.
I know what you mean, one of the most enjoyable series Id had the pleasure of seeing, I thought the movie complemented it nicely, although I disliked the killing off of characters since I really hope they would continue with the series seeing what a huge success the movie / series became. Ah well, I'm sure they can introduce equally interesting new characters, the joy of the program was the character development I felt.
Well Micky, it seems that you aren't Steve Tarani's alter ego.... Def
very true, a true expert is someone who can use what is around them, have to be able to adapt to changing situations otherwise you become extinct.
