It's the reason I made mine.
Quote from: Gareth on August 27, 2009, 07:55:34 PMIt's the reason I made mine. What...no Spurtles?
Quote from: Spork on August 27, 2009, 10:56:10 PMQuote from: Gareth on August 27, 2009, 07:55:34 PMIt's the reason I made mine. What...no Spurtles? No, but it's not a bad idea.
Here's my take on the subject. It started life as a Hiker, I removed the opener layer (and so also the split-ring), flattened out the edge and made a very acute angle on the small blade. I liked the idea of having the saw there so as I could gather the wood with it as well.(Image removed from quote.)That said I'm still not any good at whittling. PS I just looked at the pic again and I've since done more on the small blade.
...How did you manage to punch another nailnick right through the blade like that? Was it tricky/hard?
Quote from: nuphoria on August 27, 2009, 04:29:32 AMI think/hope it's his fingers Lovely mods... I like taking the opening layer out too as it's mostly redundant in these things.How does one go about getting lovely mosaic pins in a SAK scale then? They look There is a mosaic pin article at SOSAKonline - you need to log in to see it.
Quote from: Spork on August 27, 2009, 05:04:05 AMQuote from: nuphoria on August 27, 2009, 04:29:32 AMI think/hope it's his fingers Lovely mods... I like taking the opening layer out too as it's mostly redundant in these things.How does one go about getting lovely mosaic pins in a SAK scale then? They look There is a mosaic pin article at SOSAKonline - you need to log in to see it.OK I'm slow. So are the Mosaic pins then just decorative and not really holding the knife together?
