I don't know about you, but didn't the old (~90s vintage) toothpicks have a little hook at the end of them, too?
I don't know about you, but didn't the old (~90s vintage) toothpicks have a little hook at the end of them, too?Plus, what's with the "large tweezers" on my Explorer Plus being the same length as the "small tweezers" on my Classic SD? On that note, all of my 91mm and my one 111mm SAKs have the "small tweezers." ._.
If no-one beats me to it I'll get a shot of the different toothpicks tomorrow (much to late now).Quote from: Sazabi on September 04, 2009, 01:01:44 AMI don't know about you, but didn't the old (~90s vintage) toothpicks have a little hook at the end of them, too?Plus, what's with the "large tweezers" on my Explorer Plus being the same length as the "small tweezers" on my Classic SD? On that note, all of my 91mm and my one 111mm SAKs have the "small tweezers." ._.AFAIK the distinction is about the size of the SAK rather than the size of the tweezers. So a "small" pair will fit in a 58mm or a 74mm SAK, a "large" pair will fit in a 84mm, 91mm or a 111mm. It's all down to the angle of the gray plastic head and how it fits in the scale.
This is a stab in the dark, but my guess would be down to ease of manufacture. They need to make a different angle on the head of the toothpick, but as the toothpick is made from a single piece of plastic they may as well make it a bit longer for the 'large' version.Not the same story for the tweezers. To make the different angled heads then all they need to make are little gray plastic bits different. The metal 'legs' can be used on both large and small, so they've cut out a whole manufacturing process by having a part common to both.
