This my moddified wave... 5334
Full Member Posts: 186
« on: May 11, 2007, 08:31:08 PM »
Don't know if this has been posted here...
This my moddified wave, took the parts from a LM kick.
1. Removed the bit holder from de wave and put the philips driver from the Kick.
2. Removed the little bit holder and put the long flat screwdriver from the Kick, this was a tight fit, because the flat sd is thicker than the small bit holder.
3. Bend the little tabs insde the handles, so it can close.
4. File the tip of the long screwdriver 1/16" so it doesn't interfire with the scissors.
5. Epoxy laptop to side of Wave. :twak:
All i need now is the bit adapter for the kick and a removable lanyard ring to try to make saws J-sews style
Admin Team Absolute Zombie Club Posts: 23,216
Re: This my moddified wave...
« Reply #1 on: May 12, 2007, 12:21:47 AM »
Howdy Chaka, welcome to Multitool.org!
Nice mod job too! I assume you needed the longer reach of the dedicated drivers, rather than the short removeable bits?
(PM me with your address, and I'll send you a saw blade to play with)
Bob
No Life Club Posts: 3,994 Improvise.
« Reply #2 on: May 12, 2007, 12:25:16 AM »
Did you use those special security bits to take it apart?
I'd like to get a Wave and mod it almost exactly like that (take out the bit holder and the scissors that I heard aren't that great) and add the longer/dedicated drivers.
« Reply #3 on: May 16, 2007, 04:19:34 PM »
Yes i like the longer reach of the drivers... BTW, thanks for your offer, PM sent...  :cheers:
and yes, i did use 2 security bits (T10), not dificult to find...
Sr. Member Posts: 422
« Reply #4 on: May 16, 2007, 07:25:24 PM »
Most of the 5 star torx LMs are now sold out, all the new ones are 6 star torx. Just ask before you buy.
Dave
« Reply #5 on: May 17, 2007, 02:34:02 AM »
Dave
Good advice there for those planning to do any mods.
Hero Member Posts: 692
« Reply #6 on: May 17, 2007, 07:51:12 AM »
Did you also grind down the pliers?
I tried a similar modification with the Charge and ran into problems since the handles wouldn't close all the way.  The pliers didn't have enough room after the longer tools were added. http://forum.multitool.org/index.php/topic,418.15.html
Another forum member, Kodiak, did a similar modification and he ground down the pliers so that the handles would close:  http://forum.multitool.org/index.php?topic=738.new
Here's a quote from his post:
Also, I had to make a little channel on the pliers head on the side. I used a dremel.
* mod.jpg (Filesize: 56.7 KB)
« Last Edit: May 17, 2007, 08:10:40 AM by supratentorial »
« Reply #7 on: May 17, 2007, 05:45:43 PM »
No grinding on the pliers. Just bend the little tabs inside handles and dremel the tip on the long flat screwdriver so it clears the scissors...
« Reply #8 on: May 18, 2007, 01:43:40 AM »
That's weird.  After the same modification of the Charge, there was a slight gap in the handles when the tool was closed because the longer tools prevented the pliers from being fully recessed into the handles.  I thought the Charge and the Wave had the same basic design.  ???
Do the handles close all the way shut on the modified Wave?  The same as on a normal Wave?  Or is there a slight gap?  Before I buy a Wave and modify it, I want to make sure that I don't run into the same problem as I did when I tried to modify a Charge.  Thanks!
« Last Edit: May 18, 2007, 01:52:34 AM by supratentorial »
« Reply #9 on: May 18, 2007, 07:19:55 PM »
According to Paola there's a small gap.
« Reply #10 on: May 19, 2007, 12:42:40 AM »
Oh... was there a multi-tool in that photo?!  :P
« Reply #11 on: May 19, 2007, 04:19:54 AM »
I wish the gap was bigger.  :(
Total Receipts: $156.88
PayPal Fees: $10.05
Net Balance: $146.83
Below Goal: $153.17
SMF 2.0.18 | SMF © 2020, Simple Machines
Page created in 0.035 seconds with 55 queries.
© 2018 Defender Web & Tool
