Surefire LED - 6P & FM35 red filter
us Offline eodtech
on: September 14, 2009, 04:24:29 PM
Both are NEW and in sealed packages from the factory
#1.)  6P LED -  BLACK
Compact (pocket sized), high-intensity LED flashlight for tactical, outdoor, and general use. Puts out a smooth, brilliant beam with four times the light of a larger two-D-cell flashlight—bright enough to temporarily blind and disorient a person by impairing his night-adapted vision. And it continues producing useful light levels for an impressive 11 hours on a single set of batteries. Lightweight, strong, aerospace-grade aluminum body resists crushing or bending. Small size, high output, and extended runtime make it perfect for self-defense, camping and backpacking, emergency/disaster-preparedness kits, or everyday carry.
FEATURES
    * Virtually indestructible light emitting diode has no filament to burn out or break; lasts for thousands of hours
    * Precision reflector creates smooth beam without spots or rings
    * Rugged aerospace-grade aluminum body, Type II anodized in glossy black
    * Coated Pyrex® window protects LED and reflector while maximizing light transmission
    * O-ring sealed; weatherproof
    * Tailcap switch: press for momentary-on, twist for constant-on
    * Patented switch lockout prevents accidental activation
    * Batteries included
#2.)  FM35 is a Red Filter for flashlights with 1.25" diameter bezel
The FM35 Red Filter produces a smooth beam of red light that will not degrade night vision as white light would. Hunters use the red filter to avoid spooking game during predawn hours - deer see poorly in the red color spectrum. The filter is also useful for close range, non-tactical applications - such as map reading -- as it reduces the intensity of light output. Applying thumb pressure to the locking tab releases the cover; a spring mechanism keeps the open cover out of the way by holding it flat against the flashlight. A cam-locking lever keeps the entire unit securely attached to the flashlight.
FEATURES
# Fits 1.25" bezels, including Z2, C2, C3, G2Z, G2, 6P, 9P
# Cam-locking lever keeps filter securely attached to flashlight
# Provides secondary protection to flashlight lens window
# Does not impair night vision
I will not break up the set at this time
BOTH shipped to a USA address US$99.00 with USPS money order
ADD 5% for PayPal
Why do I carry a 45 ?
us Offline eodtech
Re: Surefire LED - 6P & FM35 red filter
Reply #1 on: September 14, 2009, 08:36:30 PM
« Last Edit: September 14, 2009, 08:39:58 PM by eodtech »
us Offline eodtech
Reply #2 on: September 16, 2009, 12:14:52 PM
 SOLD - September  16, 2009
