Hi, I have an old 74/75mm with some sort of tortoise shell colored scales, could be shell, but maybe not. The knife looks like a 84mm Pocket Pal or 74mm Accountant but with exposed pins and just two blades. SAKwiki had the Accountant at 84mm but I moved it to 74mm as my other 0.68xx series knife also only measures 75mm.Back to the problem, this knive has 3 exposed pins, unfortunately the main one serving the main blade pivot is loose and the scales/layer can spread open on the one end making the blade wobbly. The other pins seem very solid, so the spreading is only a couple mm. By looking at the tang & blade I'd say someone abused this poor knife trying to pry something. How can it be fixed? Are these pins actually peened to the scale, meaning once they pull through the scale material, only a bigger pin could be used? Or is there some trick when the pins are exposed? The loose side appears to be the bottom, where the pins seems naturally slightly recessed in the scale material, where as on the top side it is definetly raised above the scale. Could I use a flat punch to try to peen the pin without damaging the scales?This could be a nice knife if it could be fixed. Should I try sending it to Vic, or forget trying to fix it and just use it as a show piece?
So there is no way to fix the existing pin, it needs to be removed an a new one found, and inserted. Sounds like a job for a master, I might have to wait for a while. Too bad I was looking forward to polishing it.Wow! Those are great pics. The one in the back without the long nail-file is like mine. I presume your's have brass liners and spacers?Put your pictures on the Wiki Neil in the 74mm gallery, it needs some spiffy pictures. You don't happen to have the model numbers for those do you?
Those are absolutely beautiful, Neil. o.o
