Just to hijack this thread.... Whoey did you add the flash (i think it's flash) pop up picture gallery when you click on a picture attachment thing? If so i don't like it!! I like the old version where it just makes the thumbnail bigger
+1 actually.
lightbox, javascriptIt's quite easy to revert actually...
If you take one of the threads in "The Shutter Shop" - you can scroll through all the hot-linked and attached images from beginning to end. That's pretty cool actually.
I'm with the frog on this one, BELLS AND WHISTLES Like this... And I can only go for one page, but I'm good with that.
Maybe the full thread works on IE only?Quote from: Shane769 on September 17, 2009, 07:38:32 PMI'm with the frog on this one, BELLS AND WHISTLES Like this... And I can only go for one page, but I'm good with that.It would be better without the annoying delay thou, new window comes up, slowly widen horizontally, then slowly widen vertically, then you see the image. And each time scrolls through them the window does the same thing, neeeee, a little taller, neeeeeeeeeeeeeeee, a little narrower, then the image shows up.
I also only get the page of the thread, not the whole thread... it's easy to tell by the counter at the bottom (1 of 9) type thing
What browser do you all use? I use Opera.
