We need pics
I have an ols champ but the blade has no markings. were the old vics not marked?thanks
I can't imagine how the tang stamp would be worn off on even one side, let alone both. I think you might have one that slipped through the QC net, but I'll let the real collectors chip in as well.
I could be wrong, but from the picture it seems to me that the blade is quite small. Isn't it a normal small blade? Those small blades don't have a stamp on it. Can you measure how long that blade is?
Quote from: Nathan on September 28, 2009, 08:15:32 PMI could be wrong, but from the picture it seems to me that the blade is quite small. Isn't it a normal small blade? Those small blades don't have a stamp on it. Can you measure how long that blade is?If it were the small blade then it would be on the wrong end of the knife since the pliers tip is right there and the shield is on that end. Also the nail nick is on the side for a large blade so it is the large blade.
You could also try making your pictures in an environment with a lot of natural light. For example taking your pictures outside, when the sun is shining.
