Quote from: Benner on October 03, 2009, 05:14:08 PMQuote from: sappyg on October 03, 2009, 05:13:22 PMyep... i just checked to make sure.Don't you trust me then? i don't trust me.
So instead of lumens, what should us Jamie newb's be looking for when assessing performance
Quote from: Mike, Lord of the Spammers! on October 03, 2009, 10:27:44 PMSo instead of lumens, what should us Jamie newb's be looking for when assessing performance Ideally you want measurements of throw/ spill and beamshots. But it really depends on what you want out of your light.
Quote from: Benner on October 03, 2009, 10:34:44 PMQuote from: Mike, Lord of the Spammers! on October 03, 2009, 10:27:44 PMSo instead of lumens, what should us Jamie newb's be looking for when assessing performance Ideally you want measurements of throw/ spill and beamshots. But it really depends on what you want out of your light.And naturally the manufactures don't really list those
Quote from: Mike, Lord of the Spammers! on October 03, 2009, 10:35:40 PMQuote from: Benner on October 03, 2009, 10:34:44 PMQuote from: Mike, Lord of the Spammers! on October 03, 2009, 10:27:44 PMSo instead of lumens, what should us Jamie newb's be looking for when assessing performance Ideally you want measurements of throw/ spill and beamshots. But it really depends on what you want out of your light.And naturally the manufactures don't really list those They are easily found though. flashlightreviews.com is a good site for example.
Quote from: Mike, Lord of the Spammers! on October 03, 2009, 10:27:44 PMSo instead of lumens, what should us Jamie newb's be looking for when assessing performance LUMEN output is useful because it is a measure of the total light pumped out by the torch.LUX measurement is useful because it is the intensity of the brightest part of the torch's beam. LUX measurement can be used to predict how far the torch will throw a useful beam.Example:20 Lumens is approximately the output of a cheap, plastic 2D supermarket incandescent torch with fresh cells.Such a torch might produce 900 Lux in the center of its beam.Take the square root of 900 to get 30.This is the distance in meters at which the torch will put 1 Lumen of light on a 1 meter sqaure target.If your eyes were totally dark adapted and you were in a dark wildnerness scenario, then that 1 Lumen per meter squared might be a useful amount of light.In an urban scenario (streetlights, porchlights, etc.) that 1 Lumen/m2 would probably be useless to see anything.Derate that 30 meter distance by half to 15 meters. This is the aprroximate distance at which a 20 Lumen, 900 Lux torch would usefully illluminate a target in an urban scenario.In other words, for use around town, a 2D incan supermarket torch is predicted by its Lux measurement to be useful out to about 50 feet. Out in the dark woods, the same light might be useful out to about 100 feet.Both of these numbers seem to fit well with the experiential reality of using such a torch, so the mathematical model is fairly good.Summary:Take the square root of the Lux measurment, which gives the useful throw in meters for a wilderness scenario.Divide that by two for an urban scenario, which gives the useful throw in meters for urban use.If you wish, multiply the throw in meters by three to get throw in feet..
I wonder how one of these stacks up against the Nitecore DI?
Quote from: Magic Bus on October 04, 2009, 12:04:42 PMI wonder how one of these stacks up against the Nitecore DI? LED output wise, the Nitecore will pi$$ all over it as the A2's LED's are meant for close up work and offer a lot of spill and nigh on no throw whatsoever. Switch to incan though, and throw wise that's where the Nitecore would struggle I expect.
The reason I went with the A2 is because I am colourblind and found that LED's outside made everything look flat and kind of greyscale. Problem is, incans eat batteries so I ideally wanted a torch where I could have LED's for inside and incan for out so I could have the better run time. This obviously fitted the bill perfectly.
Quote from: Benner on October 04, 2009, 05:09:10 PMThe reason I went with the A2 is because I am colourblind and found that LED's outside made everything look flat and kind of greyscale. Problem is, incans eat batteries so I ideally wanted a torch where I could have LED's for inside and incan for out so I could have the better run time. This obviously fitted the bill perfectly.Can't fault your logic I wonder how robust the incan bulb is? I take it it's got to be better than a Maglite incan bulb
Can't remember now. Got it used from the US and then upgraded the bulb to a HO Lumens factory one. All in I believe it was in the £70's.
what does incan mean?sorry to go off topic
I don't carry any spares.
Quote from: ryan1835 on May 05, 2010, 10:11:13 PMwhat does incan mean?sorry to go off topic It's not really off topic, since the A2 is partially incan.incan=incandescent The high output mode emits from an incandescent bulb rather than an LED.
