i looked at one at a walmart the other day. I could barely get the pliers or the knife open. Is this a common thing? I dont mind plier stiffness, but a knife has got to be smooth and easy.
I like the look of them just really wish they had kept the bit driver in it Saying that I love the clip if it is the same as the Skeletool and will probably have 1 sometime in the future
How does its blade stack up/compare to the LM c301? I don't EDC my c301, but it's typically my go to blade when I'm at home...easy to open, easier to find that the SAK that's always in my bag, and cuts like a dream. Would a Freestyle be as good a replacement blade for that as say the Buck X-Tract? The Freestyle pliers look a bit nicer, sturdier, and deployable than the X-Tract's.
Quote from: turbov21 on November 05, 2009, 09:44:14 PMHow does its blade stack up/compare to the LM c301? I don't EDC my c301, but it's typically my go to blade when I'm at home...easy to open, easier to find that the SAK that's always in my bag, and cuts like a dream. Would a Freestyle be as good a replacement blade for that as say the Buck X-Tract? The Freestyle pliers look a bit nicer, sturdier, and deployable than the X-Tract's.I have a Buck X-Tract 730 and I also have both a Freestyle and a Freestyle CX. The X-Tract pliers aren't even in the same league as the Freestyle's. The X-Tract blade is larger but if you get the Freestyle CX it's blade is 154CM, but a plain edge not a combo edge like the X-Tract and not as large as the X-Tract. The X-Tract has the straight and phillips drivers on it too, the Freestyle doesn't have any drivers. I like the Freestyle much better but wish Leatherman had added a bit driver to it.
Quote from: 1jump2many on November 06, 2009, 05:17:40 AMQuote from: turbov21 on November 05, 2009, 09:44:14 PMHow does its blade stack up/compare to the LM c301? I don't EDC my c301, but it's typically my go to blade when I'm at home...easy to open, easier to find that the SAK that's always in my bag, and cuts like a dream. Would a Freestyle be as good a replacement blade for that as say the Buck X-Tract? The Freestyle pliers look a bit nicer, sturdier, and deployable than the X-Tract's.I have a Buck X-Tract 730 and I also have both a Freestyle and a Freestyle CX. The X-Tract pliers aren't even in the same league as the Freestyle's. The X-Tract blade is larger but if you get the Freestyle CX it's blade is 154CM, but a plain edge not a combo edge like the X-Tract and not as large as the X-Tract. The X-Tract has the straight and phillips drivers on it too, the Freestyle doesn't have any drivers. I like the Freestyle much better but wish Leatherman had added a bit driver to it.Then you would have a Skeletool.
Many like the carabiner as a form of carry though, it is more than just a bottle opener (and a good one at that if I remember correctly). I can't see LM phasing them out.
I've been pocketing my Freestyle to work the last couple of weeks. Only one day did i wish i carried the Wave. I needed a #2 phillips.They make it in regular blade don't they? Not the half serrated?
I have mentioned this on other threads and I hate to beat a dead horse but if Leatherman had put a bit driver on the Freestyle it would be the perfect "pocket" tool, for me.
Quote from: 1jump2many on November 20, 2009, 12:57:25 AMI have mentioned this on other threads and I hate to beat a dead horse but if Leatherman had put a bit driver on the Freestyle it would be the perfect "pocket" tool, for me. Once or twice
