Does this answer anything http://ledlightsathome.com/2007/12/07/a-lesson-in-color-temperature/
That's a good article, but it's not the full story... Thing is, there's no such thing as a "white" LED. The "white" LEDs in our torches (regardless of color temp) all start out life as a blue-emitting diode. In the manufacturing process, yellow phosphor is added to the die to shift the spectrum of the LED toward white. This is not only why some LEDs are bluer or some are yellower, depending on the amount of phosphor applied, but also why the die of the LED is yellow in color. You are seeing the phosphor sitting on top of the die.I can show you some white 5mm LEDs that are very blue or purple, and I can show you some that are quite yellow.
Quote from: NutSAK on October 31, 2009, 03:01:15 PMThat's a good article, but it's not the full story... Thing is, there's no such thing as a "white" LED. The "white" LEDs in our torches (regardless of color temp) all start out life as a blue-emitting diode. In the manufacturing process, yellow phosphor is added to the die to shift the spectrum of the LED toward white. This is not only why some LEDs are bluer or some are yellower, depending on the amount of phosphor applied, but also why the die of the LED is yellow in color. You are seeing the phosphor sitting on top of the die.I can show you some white 5mm LEDs that are very blue or purple, and I can show you some that are quite yellow.Good explanation.One minor quibble is that the phospor isn't really shifting the frequency of light from the blue LED. Frequency shifting is an optical technique, but that's not what is happening here.Rather the phosphor is absorbing photons emitted from the LED, then emitting photons at more desirable frequencies centered around yellow.Small variations in the amount of phosphor applied and its distribution with respect to the LED will have big visible effects on the output..
This is all very interesting but remember you can have the following tint variants: Whitegreen(yucky)yellowbluepinkishredbrownishand one of my favourites ANGRY BLUE any led can be tint shifted to blue if over driven
