Login
Register
Menu
Home
Help
Forum
Non Tool Forum
Flashlight Forum
Thrunite XP-G R5 LED Drop-in
kwakster
6 ·
7239
« previous
next »
Print
Pages:
1
Go Down
kwakster
No Life Club
1,006
on:
January 06, 2010, 07:02:42 PM
Together with the Catapult i also bought this;
A ThruNite P60 Style Cree XP-G R5 LED- MULTILEVEL drop-in LED module which i wanted to use in an older type Surefire G2 Nitrolon.
Three output levels: High -> Medium -> Low accessible via 'soft press' of the flashlights power switch!
• 300 Lumens (1A Drive Current)
• 3 Output Modes H -> M -> L - 100% > 40% > 1% = 300 lumen -> 120 lumen -> 3lumen
• 2.7-9V input voltage
• Cree XP-G R5 LED
• Outer spring is removable for some fitments
• Aluminium textured/OP reflector with bronze heatsink base
• Bezel diameter: 26.5mm
• Copper base diameter: 19mm
• Height including support spring: 36.7mm
• Height excluding support spring: 28.8mm
Fits to the following lights:
Blackhawk Falcata, Boker B0006, Brinkman Legend, Maxfire (LX models on both), Cabela's XPG (Xenon models), Dereelight CL1H (all Versions), DealExtreme {DX} HF-19, SKUs' ~ 1284, 4226, 14329, 14597, 14902, 15159 (DIY chassis), 15565, 15561 & OEMs, G&P T6, T9, T12, R12, Hellfighter X-4, X-8, Huntlight FT-01PJ, FT-01X SE (Luxeon versions on both), Kaidomain KD Tough, & OEMs, Leupold MX series w/ MX-100 bezel, M812, Mega CREE Q2, Nextorch (vaious models), Pelican M6 (newer version M6)...Slight modifications needed, PentagonLight X1, Xenon chassis {to be confirmed}, Pila GL2/3/4, Romisen RC-E4, RC-M4, RX-A, Smartfire A-1,T1, Solarforce L2, SF6, SF9, SF12, Spiderfire Q5, R2, X-O3, Superfire C1, see Ultrafire models, Surefire {SF} 3P, 3R, 6, 6P, 6PD, 6PL, 6R, 6Z, 7Z, 9P, 9Z, C2, C3, D2, D3, G2, G2L, G2Z, G3, G3L, GZ2, M2, Z2, Z3, Various Weaponlight models, Tactical Operations Products Stryker (slight modifications necessary), Xenon models, Trustfire T1-Q5, TR-B1/2/3, TR-C1 & 2, TR-Q5, TR-C2, Ultrafire 6P, 9P, 12P, C1, Alpha-C1, L2, WF-501A/B/C/D, WF-502B/C/D, WF-503B, Wolf-Eyes (See dimensions), XLight HA-III Cree Q3 kit, HA-III Cree Q5 XTAR P4
Thrunite website:
http://www.thrunite.com/
This is my Surefire G2:
And here are a few beamshots;
Testshot on 20/25 meter:
Surefire G2 with original P60 lampunit:
Surefire G2 with Thrunite XP-G R5 LED Unit on low:
Surefire G2 with Thrunite XP-G R5 LED unit on high:
Mike, Lord of the Spammers!
Chief of the Absolutely No Life Club!
Abandon All Hope Ye Who Enter Here...
42,975
Why haven't you got a Farmer yet!
Re: Thrunite XP-G R5 LED Drop-in
Reply #1 on:
January 06, 2010, 09:32:52 PM
Your neighbors must bloody love you
Damned impressive though
Black Rose
Hero Member
587
Reply #2 on:
January 07, 2010, 06:34:45 AM
Just be careful running that drop-in on high with the Nitrolon head on the G2.
The Nitrolon head does not disperse the heat as well as an aluminum head, so the LED could be damaged if it gets too hot.
kwakster
No Life Club
1,006
Reply #3 on:
January 07, 2010, 07:43:26 AM
Yes, i'm aware of that, and a little caution indeed goes a long way,
The drop-in does make contact with the metal inner housing though, so that must at least help some with dispersing possible heat build-up, but i still won't run it carelessly on high for extended periods.
By the way, the beam quality is a very functional mix between hotspot and sidespill.
I'm quite happy with it,
pmoore
Newbie
22
Make what you need from what you have.
Reply #4 on:
January 08, 2010, 04:44:42 PM
Looks like it has a good but of spill compared to the incan unit. Should be a good one.
Paul
K
thebullfrog
No Life Club
2,277
Reply #5 on:
January 08, 2010, 08:50:59 PM
Wow. I really like that set-up. Mind if I ask what that drop in cost you? It might be worth it for me to get an old used G2 (or something else it'll fit in) and use the drop in.
EDIT: just saw that they go for only around $40ish. Battery Junction has 'em on sale for $35. Not bad at all. Now I'm really impressed. With a cheap donor body that could be a real nice way to get myself a new light when I have some funds
Last Edit: January 08, 2010, 09:06:08 PM by thebullfrog
Print
Pages:
1
Go Up
Forum
Non Tool Forum
Flashlight Forum
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$115.65
PayPal Fees:
$7.03
Net Balance:
$108.62
Below Goal:
$191.38
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
