I've been thinking about this setup for awhile now. I wanted something that could fit in the side pocket of my Maxpedition jumbo and have most of the tools that I use daily. I wanted to keep the weight to a minimum and the size compact. There are a couple of other things that I will still add when I get them, but until then I'm really happy with this setup.Anyway, here are the pix: (Image removed from quote.)(Image removed from quote.)(Image removed from quote.)If you guys see somthing that you think I'm missing please post here and let me know, I'm open to all ideas.
An extension for Vic Ratchet, holds in place better and gives longer reach. Nice kit GG
If it t'were me I would swap the 4" crescent for a 4" Snap On slip joint plier , you are off to a pretty good start ! I use the other version of the UTA . I'm gonna give the problem some more thought .Chris
Quote from: donvito on January 17, 2010, 12:52:42 AMAn extension for Vic Ratchet, holds in place better and gives longer reach. Nice kit GG Where do I get one? Any pix?? Dave, that would be cool!
Quote from: Styerman on January 17, 2010, 01:09:11 AMIf it t'were me I would swap the 4" crescent for a 4" Snap On slip joint plier , you are off to a pretty good start ! I use the other version of the UTA . I'm gonna give the problem some more thought .ChrisChris, why the Snap-On? Better quality?
The 4" crescent has only about 1/2" of maw , the slip joints go a bit wider . Plus , I trust them more for cutting hard stuff . I'll get a few pics up ASAP .Chris
Quote from: Gadget Guy on January 17, 2010, 01:07:28 AMQuote from: donvito on January 17, 2010, 12:52:42 AMAn extension for Vic Ratchet, holds in place better and gives longer reach. Nice kit GG Where do I get one? Any pix?? Dave, that would be cool! It's the one in the middle of the pic, you can probably use any bit adapter/extender. It goes into the ratchet (making an L shape) and the bit is placed in the shorted end of the L. Mine came with it.
Quote from: donvito on January 17, 2010, 01:18:56 AMQuote from: Gadget Guy on January 17, 2010, 01:07:28 AMQuote from: donvito on January 17, 2010, 12:52:42 AMAn extension for Vic Ratchet, holds in place better and gives longer reach. Nice kit GG Where do I get one? Any pix?? Dave, that would be cool! It's the one in the middle of the pic, you can probably use any bit adapter/extender. It goes into the ratchet (making an L shape) and the bit is placed in the shorted end of the L. Mine came with it. Oh... the Leatherman extender should work then. Thanks for the tip, I'm getting one.
Quote from: Gadget Guy on January 17, 2010, 01:21:21 AMQuote from: donvito on January 17, 2010, 01:18:56 AMQuote from: Gadget Guy on January 17, 2010, 01:07:28 AMQuote from: donvito on January 17, 2010, 12:52:42 AMAn extension for Vic Ratchet, holds in place better and gives longer reach. Nice kit GG Where do I get one? Any pix?? Dave, that would be cool! It's the one in the middle of the pic, you can probably use any bit adapter/extender. It goes into the ratchet (making an L shape) and the bit is placed in the shorted end of the L. Mine came with it. Oh... the Leatherman extender should work then. Thanks for the tip, I'm getting one. The LM extender works, but wobbles and drops free when tipped. It's not a great fit with my skele ether, side to side play is terrible
Very nice mate, oddly enough I've just been thinking about adding a Bahco 4" adjustable spanner (known as a 'shifter' to us Brits) to my EDC. The Engineer in me just hates using toothed jaws to turn nuts and bolts.
Quote from: Gareth on January 17, 2010, 01:44:24 AMVery nice mate, oddly enough I've just been thinking about adding a Bahco 4" adjustable spanner (known as a 'shifter' to us Brits) to my EDC. The Engineer in me just hates using toothed jaws to turn nuts and bolts. Thanks Mate! Do you have a picture?I really want to add an Atwood ruler to my setup, but I need to find one first.
I've been looking all over for a folding, steel ruler. I haven't seen one yet
Quote from: Gadget Guy on January 17, 2010, 02:03:21 AMQuote from: Gareth on January 17, 2010, 01:44:24 AMVery nice mate, oddly enough I've just been thinking about adding a Bahco 4" adjustable spanner (known as a 'shifter' to us Brits) to my EDC. The Engineer in me just hates using toothed jaws to turn nuts and bolts. Thanks Mate! Do you have a picture?I really want to add an Atwood ruler to my setup, but I need to find one first. not of my own, as I don't have one yet. I do have other Bahco shifters though and the quality is top notch.(Image removed from quote.)
nice setupand thank you for the trade!
