What kind of tamper resistant nuts are on the Super Tool 300?
us Offline tonytools
They look like some 30 piont drive, are they a custom thing Leatherman has?
Are there special driver tools you can buy for these?
Thanks, Tony.
They are proprietary fittings (we tend to refer to them as "knurled" screws around here), and alas you cannot buy a tool for removing them.
The smaller screws (the ones that  attach the knife and component tools) can be manipulated using a couple of Kick pocket clips, but the plier head end uses larger screws.
Thanks for the information Dave.
At least I can get to some of them :D
us Offline Tsquare
While we are on this subject does anyone know what size the plier end pivot pins are on the 300 and on the contour models. I know the tool side is 3/16 inch.  If anyone has taken the plier side apart let us know.
I emailed LM about what they call them and they call them knurled screws as well :tu:
I believe DaveK has taken that side apart as well but he has the tools to do it :D Perhaps he will be back in a few and let us know :tu:
I did, but I didn't measure anything guys, sorry.
Offline Anthony
  • Improvise.
Search and you will find a very informative thread by (I'm 99% sure..) the member Spoonrobot.  It involves a rubber mallet and a cheap socket set 8)
Plier side is 3/16 also :salute:
I think I might have an idea; I will post the results when my tool comes in the mail.
It will be fun so stay tuned, I will post even if it fails to work out. :salute:
Standing by for some fun........ :salute:
us Offline BIG-TARGET
Re: What kind of tamper resistant nuts are on the Super Tool 300?
Reply #10 on: March 27, 2010, 05:00:42 AM
Some people don't like their nuts played with! ::)
Reply #11 on: March 28, 2010, 01:41:00 AM
Is that a leatherman or Pulp Fiction Joke?  8)
Reply #12 on: March 28, 2010, 01:44:58 AM
Pick one ::)
us Offline Marlinaholic
Reply #13 on: March 29, 2010, 06:49:02 AM
Testicle jokes aside, why does Leatherman use those goofy knurled nuts AND "normal" security torx construction?  You would think for consistency they would just pick one system (hopefully the torx) and use that for ALL production.  Wouldn't it be simpler for them to use one kind of fastener?  Wouldn't it save money on inventory ect?  No way using more varied kinds of fasteners makes sense from a business standpoint, I just don't get it.
Reply #14 on: March 29, 2010, 06:56:01 AM
Though I was being a bit double entendre, Leatherman probably doesn't want a half baked fool trying to take their multitool apart , then ship it back to LMbecause the idiot forgot how to put it back together :think:
Reply #15 on: March 29, 2010, 09:25:21 AM
It is odd , they use tamper proof Torx fasteners , which we all like as tamper proof tool bits are readily available  :D :D :D.
I am wondering if the ST 300 got the knurled fasteners simply as a carry over from the Core model it replaces :think: :think:.
Be interesting too know how they decide which model gets Knurled & which gets Torx  :think:
They probably have truck loads of knurled fasteners in stock  :think: :think:
us Offline Spoonrobot
Reply #16 on: March 29, 2010, 01:58:09 PM
Seems like they added the 5-lobe Torx TX for the Wave since it uses bolsters on the implement ends and much larger head diameter hardware at the blade ends. Seems like the trend has continued, any tool with bolsters gets the Torx hardware and anything with one-piece handles gets the knurled fasteners.
Not quite sure what the difference is between the Charge Ti and the Al that makes one Torx and one knurled. Ditto with the Sideclip.
Reply #17 on: March 29, 2010, 06:40:13 PM
The query was not why do they use them, more why do they use readily available torx AND the knurled fasteners.
Reply #18 on: March 29, 2010, 07:39:59 PM
In addition, why did they move from the 5-pointed torx fittings to 6? 5 point security torx bits are much harder to find, and therefore more secure you'd think!
Reply #19 on: March 30, 2010, 01:12:23 AM
Ok here is my test JB weld using socket nuts.  I have to wait 15 hours for full cure.
1. Test sockets
2. What is needed, two sockets, grinding bur, alcohol to clean surface, Play-Doh, mini paint brush, Q-tips, masking tape and mixing sticks.
3. Grinding out sockets, so JB Weld will stick to the socket.
4. Play-Doh in sockets to keep JB weld from coming out through the top.
5. Clean sockets with alcohol and Q-tips.
6. Mask Leatherman super tool 200.
7. Use paintbrush and Vaseline to keep JB Weld from sticking to metal.
8 and 9. Mix JB weld
11. Top off JB Weld in sockets.
12. Put JB Weld on Leatherman and clamp.
13. Leatherman is clamped and wait 15 hour for cure time.
Will post results when it drys or I cry.
Tony ::)
* leathermansmall.jpg (Filesize: 69.26 KB)
us Offline BlueDot
Reply #20 on: March 30, 2010, 01:15:49 AM
Great idea.  Hope it works.
There are just 10 types of people in the world:  those who understand binary number systems, and those who don't
Reply #21 on: March 30, 2010, 05:44:22 PM
First try did not work.
Will try agian, here is what I will do different.
1.  Measure out JB Weld with digital scale, then mix it.
2.  Add metal dust with epoxy to help hold it together.
* epoxyfail1.jpg (Filesize: 45.33 KB)
Reply #22 on: March 31, 2010, 12:47:26 AM
Good luck mate , but when I tried with JB Weld putty I got good impressions but the impression got stripped out by the LM knurled fastener when I used it :(
Offline Big D
  • New User
Reply #23 on: February 18, 2024, 12:46:00 AM
Why don't you cnc a part up mu h easy to make it out of stell
us Offline VICMAN
Reply #24 on: February 18, 2024, 01:32:06 AM
Thanks, Tony.
Here is a URL for Ebay showing wrenches for Leatherman Multitools:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=wrench+for+disasswmbling+leatherman+mulrtitools&_sacat=0&_odkw=wrenchmulrtitools+for+disasswmbling+leatherman+&_osacat=0
Reply #25 on: February 18, 2024, 02:01:33 AM
Welcome to  :MTO:  :cheers:
