That looks like a good job Robert.
Thanks guys.One good tip Zed. Don´t put to much glue on it, the first time i did this, i glued all my tools shut I had only put some of the glue in the holes i drilled for the rivets, that should hold just fine.
have you thought about getting a wood burner pen and stenciling your name on it?
That came out nice What are you planning on doing next?
I think I am gonna machine my own aluminum scales. not sure about the finish yet though.
Quote from: gadgetguy35 on March 28, 2010, 05:08:25 PMI think I am gonna machine my own aluminum scales. not sure about the finish yet though.cool idea GG, sadly im limited to wood or softer material,
Looks good, Paul..
Looks gentleman style, very nice job!
great work bro Maybe you should do Mircarta, like i did aluminum is not that hard to work with, if you like it, you should give it a try
Will the Ali tarnish?Will you have to seal/varnish it?
Quote from: Argento on March 28, 2010, 09:26:09 PMgreat work bro Maybe you should do Mircarta, like i did aluminum is not that hard to work with, if you like it, you should give it a try i could cut and work ali as pretty soft and i do like mircarta but where do you get it from, ?paul
