I believe it's a dual pro with a PE.
Quote from: thebullfrog on April 05, 2010, 09:25:05 PMI believe it's a dual pro with a PE.Correct, I should have explained more. It has the PE main blade and serrated emergency blade and a corkscrew.
Quote from: felinevet on April 05, 2010, 09:27:51 PMQuote from: thebullfrog on April 05, 2010, 09:25:05 PMI believe it's a dual pro with a PE.Correct, I should have explained more. It has the PE main blade and serrated emergency blade and a corkscrew. So does it have the corkscrew or the phillips. You say CS, pic says phillips.
How much will they be?
