Battery storage
Battery storage
on: April 05, 2010, 09:58:05 PM
Battery storage
Does anyone have any good ideas of how to organise your rechargeable batteries?
I have a little pile of 'empties' on the left of the charger and a couple of 'charged' on the right of the charger,
A bit untidy,  :ahhh
Any ideas please?
Re: Battery storage
Reply #1 on: April 05, 2010, 10:01:26 PM
Re: Battery storage
Reply #2 on: April 05, 2010, 10:08:08 PM
I have moulded AA battery holders and then number sets so I know what are dead etc.
Re: Battery storage
Reply #3 on: April 05, 2010, 10:09:15 PM
Can't see the pic Mate  :(
'This purchased item information is no longer available'
Re: Battery storage
Reply #4 on: April 05, 2010, 10:12:18 PM
Holders marked empty and charged?
Sets of batteries with numbers taped on them?
Re: Battery storage
Reply #5 on: April 05, 2010, 10:15:24 PM
No, just holders with the batteries numbered - say 3 sets of 4, 4 of them numbered one, then 4 numbered 2 etc.  I then use them in order, the "3's" followed by the ones again.
Re: Battery storage
Reply #6 on: April 05, 2010, 10:29:03 PM
I'm getting in a mess with which ones are charged or not
Thought I would ask here for ideas so I'm still thinking....... needs to be easy for me to do without putting in any effort  ::)
us Offline Blackbeard
  • One Day Closer To Death
Re: Battery storage
Reply #7 on: April 05, 2010, 11:12:28 PM
Get some small plastic storage bins/organizers with multiple compartments inside, and some have movable plastic slats so you can adjust the size in the interior. You can find them at hardware or fishing supply stores.
http://www.sears.com/shc/s/p_10153_12605_SPM197754047P?keyword=plastic+storage+tackile+box
http://www.sears.com/shc/s/p_10153_12605_00912288000P?keyword=plastic+organizers
« Last Edit: April 05, 2010, 11:14:49 PM by Blackbeard »
BB :B:
Re: Battery storage
Reply #8 on: April 06, 2010, 01:58:01 AM
Count up number of batteries you have, grab a lump of wood and drill that many holes about 30mm deep with a 15mm bit.  Job done :D
Put your flat cells in your fancy pants new holder negative up and your charged ones positive up :tu:
Offline P35
Re: Battery storage
Reply #9 on: April 06, 2010, 02:32:25 AM
keep mine in the charger, trickle keeps them topped off .
ca Offline Black Rose
Re: Battery storage
Reply #10 on: April 06, 2010, 03:40:52 AM
That's a great way to ruin your batteries.
Re: Battery storage
Reply #11 on: April 06, 2010, 03:43:42 AM
Battery storage
This pic is about a year and a half old (I have even more batteries now), but this is what I keep my charged batteries and any primary cells in (I've gotten rid of most of my alkaline cells)
I have some AA & AAA battery cases I got at one of the local dollar store chains.
They are divided in half, one side has "New" on it and "used" on the other.
« Last Edit: April 06, 2010, 03:46:14 AM by Black Rose »
Re: Battery storage
Reply #12 on: April 06, 2010, 09:38:48 AM
Thanks for all the ideas Guys  :cheers:
Still open to suggestions (I need to make it fool proof)  :rofl:
Re: Battery storage
Reply #13 on: April 06, 2010, 11:42:54 AM
Aside from my case idea, your next best solution is to get a multimeter so u can see which ones are charged/dead
Offline P35
Re: Battery storage
Reply #14 on: April 06, 2010, 09:35:50 PM
not if you have a quality charger
Re: Battery storage
Reply #15 on: April 06, 2010, 09:39:16 PM
Rubberbands..? Green - Charged / Red - Dead...  :think:
ni-ulster Offline cerbera147
Re: Battery storage
Reply #16 on: April 06, 2010, 09:41:47 PM
That's a helluva lot of batteries  :o
us Offline NutSAK
Re: Battery storage
Reply #17 on: April 09, 2010, 05:53:21 PM
The only type of cell that should be trickle charged is lead acid.  According to battery manufacturers NiCd, NiMH, and Li-Ion (especially Li-Ion) should not be constantly trickle charged, regardless of what charger you have--though the charger manufacturer may claim it's OK.  A .01C - .05C trickle would be OK for 12-24 hours or so, but any amount of trickle charging beyond that will reduce the overall service life of a NiMH or NiCD cell.
If you have quality (LSD) NiMH cells, they don't need to be trickle charged.  They will be at ~80% charge after sitting on a shelf for a year.  If you want a lower self-discharge rate than that, pop your cells in a sealed container in the refrigerator.
I'm with Black Rose.  I use a similar setup for my 60 or so NiMH and Li-Ion cells.
« Last Edit: April 09, 2010, 06:01:49 PM by NutSAK »
- Terry
Re: Battery storage
Reply #18 on: April 10, 2010, 07:13:39 AM
Those are just the spares.
I currently have 164 NiMh batteries (AA, AAA, C, D), 6 Li-Ion cells (need more), around 40 Energizer Lithium AAs, and 24 CR123A lithium primaries.
I had more NiMh cells, but I gave 24 of them to a CPFer.
Offline freethink
Re: Battery storage
Reply #19 on: April 13, 2010, 08:55:58 AM
@ blackrose:  Wow, that's impressive.  I was going to post my refrigerator setup, but it's pathetic compared to that.
