I'm working on a review... but here's some pictures for you guys to enjoy until I can finish it
Nice pics as usual Mikey!Any initial thoughts on it?Def
The phillips driver is junk... I can hardly get it to work at all...
I still hate the suspension and I feel they should all be removed from the face of the planet!!!! ;D
There's just nothing exciting about the Suspension. Simply put, it's a mediocre tool...
The spring loaded pliers are a nice function, but can get annoying during certain tasks.The large handles are nice and give you a decent grip... but using them for anything large and the handles are extremly uncomfortable.
The knife blade is good... as well as the flat blades.The phillips driver is junk... I can hardly get it to work at all...
The combo can / bottle opener looked promising, but I can't open a can with the can opener, no matter how hard I try.The scissors are still not marked "Fiskars!!!!!!"
Have to respectfully disagree, 665ae. I've been using my Suspension a lot lately, and I've been liking it more and more.Great plier ergonomics, easy one-hand-opening blades, and easy tool extraction from the handles all count for a lot with me.Recently examined a SOG Powerlock, which obviously has better fit and finish and overall robustness than Suspension.However, Powerlock's tools are not quickly and easily available like Suspension's. Powerlock's knife isn't instantly available for one-hand cutting tasks.Powerlock costs TWICE as much as Suspension at my local Lowes. Can Powerlock handle twice the tasks as Suspension? Is Powerlock twice as easy to use as Suspension?I'm sure the SOG Powerlock is a great multitool for heavy duty use. But, for many people Suspension would work as well or better than Powerlock for casual tasks around the house. Suspension is easier to use and half the price of Powerlock.
I love Suspension's pliers. In the last few weeks I have used Suspension to replace an old electrical wall socket and to rewire an electric lawnmower, in addition to other uses.The wall outlet had been poorly installed and replacement required lots of pliering. Suspension's pliers were used to repeatedly grab hold and then forcefully crack off pieces of wood paneling to enlarge the hole for the new outlet. Worked great.My five-year-old Black and Decker lawnmover caught fire while I was mowing last week. The motor had been surging for about half-an-hour and I thought I smelled something burning. Suddenly clouds of black smoke came boiling up out of the plastic housing containing the lever-activated dead-man switch and power connection for the electrical cord.I had to go in the house to get a nutdriver with the proper Torx bit, but other than that the Suspension easily handled the repair. The end plug on the extension cord had melted and fused into the plasic housing. One of the copper connector blades that mates with the extension cord was burned and partially melted.Repair required removal of the power connectors and modification of the plasic housing. Cutting, stripping, and splicing. Connector blades pried loose and the plasic housing was completely modified to allow direct splicing of the extension cord to the wiring inside the housing.All of that was accomplished using the Suspension's excellent pliers and knife blades. By the time I had finished the job, I was more impressed than ever with the Suspension. A very versatile tool.
The can/bottle opener is not the best design, but I was able to use it to open a can. The length of the implement makes it awkward, but I rarely use a multi to open cans. I do prefer the Victorinox-style opener over all the other styles I've tried.The scissors work great given their small size. I've used them to open a plastic clamshell pack and cut cardboard packaging and paper. They work fine if you make short cuts and don't get in a hurry.
I don't agree on the plier ergonomics. I think it has more to do with the size of your hand than anything with the design. I think the Suspension would feel better to people with larger hands. The one thing I do like is the rubber sections on the ends of the handles that add to comfort when using the pliers.
For the record... I'm not a big fan of the PowerLock either.
I'm a firm believer in the idea that people have different tastes. I'm glad to hear that the Suspension works well for you, and that you like it
I use the can opener on multitools quite a bit. (I eat a lot of chunk chicken ) When I tried using the opener on the Suspension, I ended up with a very jagged edge and a deformed rim, which after 1/2 way around the can made it very hard to continue.
I know a guy that just happens to have one FOR SALE.
