Where to get food grade mineral oil? thanks guys
Quote from: John on May 07, 2010, 10:08:10 PMWhere to get food grade mineral oil? thanks guys Look in a pharmacy; they're sold as laxatives, but it's all the same.
Quote from: NutSAK on May 07, 2010, 09:29:07 PMI personally wouldn't ever consider lubricating anything with WD-40. It is designed to displace water, not lubricate.Though commonly repeated, this is not completely true. Not only will it help disperse water, it will also lubricate. It's even advertised as such. Really, is there any reason to believe that WD40 will not lubricate? Look it up. It's just thinned oil. I suppose it won't work well in the crankcase of an old Ford. But for knives and hand tools, it works just fine. This same nonsense goes on with bicyclists. Mention WD40 as a chain lube on bike forum, and watch about half the heads explode, claiming a whole litany of reasons it will destroy your precious bike, usually starting with the trope, "...but it's designed to displace water!". The other half will say they've used it for years and never noticed anything bad as a result.
Hey guys, thanks for all the great feedback. Seems like there is some divide over the effectiveness of WD40 as a lubricant. Well, I'll have to invest in some nano oil and mineral oil to compliment the WD40. By the way, my wife is now convinced I am a total loser for asking you guys about lubing my MTs.Ryan
Quote from: Sazabi on May 07, 2010, 10:20:21 PMQuote from: John on May 07, 2010, 10:08:10 PMWhere to get food grade mineral oil? thanks guys Look in a pharmacy; they're sold as laxatives, but it's all the same. A pharmacy? Hmm! I think I'll take my tool along and show them exactly what wants lubricating,I don't want them to get the wrong idea
Quote from: shecky on May 07, 2010, 09:46:16 PMQuote from: NutSAK on May 07, 2010, 09:29:07 PMI personally wouldn't ever consider lubricating anything with WD-40. It is designed to displace water, not lubricate.Though commonly repeated, this is not completely true.Yes, that statement is completely true. WD-40 was not designed as a lubricant. It was designed specifically to displace water and prevent corrosion. It does contain thin oil, but to lubricate is not it's primary use and should only be substituted for a proper lubricant as a last resort, IMO. There are much better products desgined and manufactured specifically to lubricate. Yes, there are many uses of WD-40 as claimed by the manufacturer, but it performs most of those "many uses" very poorly.I was a bicycle mechanic for 10 years, and I told hundreds of customers to never apply WD-40 to their chains--for good reason. I saw the results of its use (grime and resulting wear) and there are much better products widely available. A chain oil should slough off dirt and grime, not gum up and attract it as WD-40 does. Call it nonsense if you will, but when asked for my advice I will continue to suggest that people use proper lubricants where they are needed.
Absolutely. Penetrating oils and the like are fantastic for, well, penetrating, and they excel at displacing water but they are too thin to properly lube metal on metal.
Quote from: Artemis on May 10, 2010, 04:21:38 PMAbsolutely. Penetrating oils and the like are fantastic for, well, penetrating, and they excel at displacing water but they are too thin to properly lube metal on metal. In my experience, WD-40 isn't a good penetrating oil either. I'll take a specific penetrating oil such as PB Blaster or Kroil over WD any day.
Quote from: NutSAK on May 10, 2010, 05:04:18 PMQuote from: Artemis on May 10, 2010, 04:21:38 PMAbsolutely. Penetrating oils and the like are fantastic for, well, penetrating, and they excel at displacing water but they are too thin to properly lube metal on metal. In my experience, WD-40 isn't a good penetrating oil either. I'll take a specific penetrating oil such as PB Blaster or Kroil over WD any day.KROIL! good stuff. Yea, WD40 is much better as a cleaner and water displacer.
Of the two I'd go with the Silicone as I think it would be the better penetrator, but that's just a gut feeling.
Quote from: Gareth on April 16, 2017, 08:50:01 AMOf the two I'd go with the Silicone as I think it would be the better penetrator, but that's just a gut feeling.That's what she said.
Quote from: ReamerPunch on April 16, 2017, 09:42:27 AMQuote from: Gareth on April 16, 2017, 08:50:01 AMOf the two I'd go with the Silicone as I think it would be the better penetrator, but that's just a gut feeling.That's what she said.
Quote from: Gareth on April 16, 2017, 10:53:32 AMQuote from: ReamerPunch on April 16, 2017, 09:42:27 AMQuote from: Gareth on April 16, 2017, 08:50:01 AMOf the two I'd go with the Silicone as I think it would be the better penetrator, but that's just a gut feeling.That's what she said. +
