De-stressing today, my guitar .
Zed · 71 · 3486
on: May 18, 2010, 12:05:34 PM
I built this guitar 5 years ago from products from WD , its been a great guitar but as i sprayed it black first and then white its got knocked a bit over the years so i decided to give it a relic type look,i also re-shaped the headstock as was a genus one before as i didnt wont a usual strat type headstock, ive got back into playing a bit lately due to stresses in life, and i chill out while playing,well as i got a meeting with my ex wed night i did this to take my mind off it, here is fletch  :D i called him that after the chevy chase movies back in the 80's caddy shake was to long  :rofl: i like reminders of the 80's good times, nd great tunes  ;) i might see if i can pick up a aged scratch plate and buttons or possibly just the buttons and pickup covers  :think:
gb Offline ryan1835
  • buh
Re: De-stressing today, my guitar .
Reply #1 on: May 18, 2010, 07:21:12 PM
if you sand the existing covers and dump them in coffee it should age them a bit i think :P
I
Reply #2 on: May 18, 2010, 07:28:59 PM
cheers ryan i wondered if there was some secret way to do it  ;)  :cheers:
gb Offline ryan1835
  • buh
Reply #3 on: May 18, 2010, 07:34:33 PM
not sure how well it works id do a sample test first, tea might work too
I
Reply #4 on: May 18, 2010, 07:46:02 PM
 :tu: im just going to try the tremolo arm tip and the selector button  :D
Reply #5 on: May 18, 2010, 07:53:47 PM
i just read that tea or coffee should do it ryan, its in the the cup as we speak  :D plus 2 tea bags for good measure  :tu:
might try this as well
you can dechrome. A galvanic element proceedure.
- 10-liter plastic buckets filled with warm water
- Stir in salt, the quantity of cooking salt determines the current flow
- start with a little salt and watch, it should go slow with the
dechroming, then add salt during the process thoroughly.
- A battery charger, with 6 / 12 volt switchable.
6 volts takes a little longer, ideal is 12 volts
- To dechrome part of the Plus terminal, with a strong wire or cable,
because the clips with resolutions.
- The plate minus any part (black plate, no refined tin)
On the sheet metal store are part of the chromium from afterwards.
- Both parts (Part Chromed and sheet metal part) in the salt solution
- Turn on the charger and voila the dechroming starts
- The chrome now migrates from the nobler part of the base plate part.
- The water you can simply dispose later, it's only water / salt solution
« Last Edit: May 18, 2010, 07:55:22 PM by Zed »
gb Offline ryan1835
  • buh
Reply #6 on: May 18, 2010, 08:51:52 PM
reverse electro plating  :D
were need pics  :pok:
I
Reply #7 on: May 18, 2010, 09:00:37 PM
dont think that will be for a while mate, but would look better looking tarnished  :tu: ok im going to look in my cup of coffee /tea   :D
gb Offline ryan1835
  • buh
Reply #8 on: May 18, 2010, 09:03:20 PM
did you scuff the finish of it first?
I
Reply #9 on: May 18, 2010, 09:03:51 PM
Just play it wearing a studded belt and throw it in a cheap flight case after every gig. It worked for me and my old strat copy :D
gb Offline ryan1835
  • buh
Reply #10 on: May 18, 2010, 09:05:19 PM
in the summer i want to strip the paint of mine and give it a natural look  :tu: anyone know how to destory poly-whatnot coat
I
Reply #11 on: May 18, 2010, 09:07:56 PM
Nitromors will shift it, but a bit like your Sideclip experiment, it's all a bit one directional once you start  :P
gb Offline ryan1835
  • buh
Reply #12 on: May 18, 2010, 09:09:00 PM
one directional... ?
I
Reply #13 on: May 18, 2010, 09:12:14 PM
my only gig is in the bedroom dave  :rofl:  ryan yes i rubbed it down with sandpaper , ill leave it in there till the morning as not much different at the moment ,
Reply #14 on: May 18, 2010, 09:13:49 PM
There ain't no turning back once you've started!
gb Offline ryan1835
  • buh
Reply #15 on: May 18, 2010, 09:16:54 PM
didnt matter in the sideclip its lovely :) i even took it with me to college lol
I
Offline Styerman
Reply #16 on: May 19, 2010, 03:14:03 AM
How do your neighbors feel about your stress management ? Cats also tend to hate it !
Chris
Reply #17 on: May 19, 2010, 09:17:28 AM
Chris
headphones  :D although my amp is crap and sounds better through my headphones, think i might have to sell some stuff and get a new amp  :-\ the one i have now is a no name thing a mate gave me about 10 years ago, the only thing i like on it is the overdrive button. its better than the distortion pedal i had,
paul
fr Offline Whoey
  • I am geek, hear me code
Reply #18 on: May 19, 2010, 10:47:52 AM
I suggest you look into a guitar pod... at least then you can play with headphones, and get some pretty good sound!
Reply #19 on: May 19, 2010, 10:52:09 AM
cheers mate ill look into that  :cheers:
here is one i would love to make a replica of,
eddie van halens frankenstrat
« Last Edit: May 19, 2010, 12:13:31 PM by Zed »
Reply #20 on: May 19, 2010, 11:54:32 AM
Made a few more changes this am , sounds more heavy rock now  :D
gb Offline ryan1835
  • buh
Reply #21 on: May 19, 2010, 02:53:11 PM
Argh my iPods not showing me the pics lol, I want to try building an OD pedal one day
I
Reply #22 on: May 19, 2010, 04:15:54 PM
give it a go mate, ive always fancied building one into my guitar, well as i keep looking at EVH frankenstrat im thinking of doing a similar paint job but more subtle  ::)   :D
yeah think ill have a go at something like this but as it was before he cut the scratch guard up and it was a white guard before so ahlg way there , just need a good before pic as there all like this,   :-\
« Last Edit: May 19, 2010, 04:58:23 PM by Zed »
gb Offline ryan1835
  • buh
Reply #23 on: May 19, 2010, 06:30:45 PM
im pretty sure i have an old humbucker you can have if you want it paul?
also did the coffee work?
« Last Edit: May 19, 2010, 06:55:13 PM by ryan1835 »
I
Reply #24 on: May 19, 2010, 07:31:49 PM
 :tu:  that would be great ryan im sure i could have a look around for something to trade,  ;) yeah it kind of worked, but not yellow enough, ill give it another go  :D
gb Offline ryan1835
  • buh
Reply #25 on: May 19, 2010, 07:36:03 PM
there s a website somewhere with loads of relic-ing tips but i just cant think of it at the moment :(
ill try sending it off at the weekend if i can find it and all that jazz
I
Reply #26 on: May 19, 2010, 07:43:48 PM
cheers mate, i do go on a forum and ive read a few things, most pretty much what you said ryan, i think ill just let it evolve now by itself  :D  :tu:
gb Offline ryan1835
  • buh
Reply #27 on: May 19, 2010, 07:54:30 PM
ultimate guitars a good one to go on  :tu:
I
Reply #28 on: May 19, 2010, 08:03:54 PM
It's funny reading this discussion, as the very thought of scratching my Les Paul causes me to panic, let alone wilfully "distressing" it  :ahhh
I used to have a Les Paul copy though which had a multi-coloured, dribbled paint effect - that was quite cool - not sure where that went actually, I seem to remember giving it to someone  :think:
Reply #29 on: May 19, 2010, 08:06:34 PM
if i had a les paul dave i would wrap it up in cotton wool, but mines a Frankenstein of a guitar and i like a more abused look, but give me a year and it will be probably restored back to new looking , im just in this kind of mood at the moment, but les pauls look nicer all shinny  :tu:
