looks like something the terminator would carry def, very cool,
Quote from: Zed on May 27, 2010, 07:28:40 PM looks like something the terminator would carry def, very cool, My response was that it looked like the regular NIRK, only infected by Borg nanytes. Hard to tell which of us is the bigger dork..... (Image removed from quote.)Def
You DO NOT want to get into Star Wars with me.... I put the guys in Fanboys to shame....Def
I think it's an over styled, tart's handbag What ever happened to clean, simple lines
Fancy, would be better without the recurve thou.Quote from: Mike, Lord of the Spammers! on May 27, 2010, 09:38:35 PMI think it's an over styled, tart's handbag What ever happened to clean, simple lines It's okay to be a simpleton, you can't control it.
Hmmm... I wouldn't mind about icky stuff, what with the open construction and all. I'd be more worried about accidentally disengaging the lock; the way I see it, it's sort of a lockback, only the whole lock bar is exposed and touches the lower portion of your (probably squeezing) palm...
Well I have four original NIRKs on the way- two black, two silver, so I plan to put them through the ringer. I'll also give one of each away to members to abuse as they see fit! Def
Quote from: Grant Lamontagne on May 29, 2010, 09:13:49 PMWell I have four original NIRKs on the way- two black, two silver, so I plan to put them through the ringer. I'll also give one of each away to members to abuse as they see fit! DefSo when are they getting here? I wanna see them. I noticed your #1 post picture was changed to a new photo...did you do that?
They are here, I'll take pics soon. I've been working a lot the last few days! In fact, I almost have a full review of it that hopefully will be seen in the trade rags soon... Def
I looked up a thread over on the USN , there are two current interpretations of the original , one being by Brian Tighe , the other by Chris Reves . The harder you squeeze the handle , the stronger the lockup becomes . The Chris Reves version has somewhat less flamboyant lines . Chris
