Spirit - grinding the file into a blade
Offline hassium270
on: August 19, 2007, 04:35:42 AM
has anyone tried this on their grinder, or do you think it possible? i was checking the stats on the file blade hardness and it seems as though its not quite as hard as the other blades, but still not too bad. it would be a thin/narrow light duty blade - is there enough meat in the file to achieve this? another blade would be more useable for me than the file, which i find nowhere near as good as a diamond type.
i know others have converted the serrated to a straight blade, but i'd like to keep the serrated on the spirit.
cheers
Re: Spirit - grinding the file into a blade
Reply #1 on: August 19, 2007, 01:31:11 PM
You probably could manage it, but due to the different tempering it wouldn't take a very good edge or hold it for any length of time.  You'd also lose the nice little metal saw built into the "bottom" of the file.
To be honest, I would suggest just carrying a small SAK with it instead of trying to mod another tool into a blade.
There are none so blind as those who will not see.
Reply #2 on: August 19, 2007, 10:16:53 PM
Why would you want to ???
I'm not having a dig at you just wondered why?
Personnely I go down the route def sugested and just get a second knife mate :)
us Offline hawkchucker
  • I miss Benner
Reply #3 on: August 20, 2007, 01:57:49 AM
Actually file steel makes excellent knife blades. As long as you dont heat it up too much you will have no issues with it. I do Reenacting of the Fur Trade era and have made several very usuable knives out of files.
But I just got to ask. Is it going to be worth the effort. I am not trying to talk ya out of it, but I just cant figure out why you would want to do this.  Can the tool be replaced with a blade?
S
Offline hassium270
Reply #4 on: August 20, 2007, 02:56:18 AM
i almost envisaged the file becoming a small type filleting blade.  even if i just used it for slicing up my apple each day it would be worth it for me...i can't stand serrateds for that kind of thing.
if i pick up another spirit cheap, i'll make that the test mule.
Total Receipts: $319.11
PayPal Fees: $17.62
Net Balance: $301.49
Above Goal: $1.49
100%
