DIY tool / blade using a Country Comm EOD Breacher Bar
us Offline eodtech
I have a couple of these EOD Breacher Bars from Country Comm
My neighbor owns a welding / fabrication shop ,
I'm going to have him grind an edge on them and I'll wrap them with paracord.
http://countycomm.com/modbar.htm
Why do I carry a 45 ?
ca Offline jzmtl
Re: DIY tool / blade using a Country Comm EOD Breacher Bar
Reply #1 on: June 17, 2010, 12:52:25 AM
Isn't the hardness too low for a knife? Only mid 40 if I recall.
us Offline Pacu
Reply #2 on: June 17, 2010, 12:56:46 AM
It would be neat to add a blood groove too. >:D
wonder how one would look with wood handles...zebra wood or oak
:like:    :MTO:
Reply #3 on: June 17, 2010, 09:50:14 AM
I need one of those 'linishers'?/grinders in the top right picture  :drool:
Reply #4 on: June 17, 2010, 10:12:23 AM
I'm with Tony :D
spam Offline John
  • Avatar removed by request
Reply #5 on: June 17, 2010, 12:00:03 PM
+1  :tu:
that and a bench grinder so I could use paper wheels and polishing mops  :D
Reply #6 on: June 17, 2010, 12:43:00 PM
Tools  :drool:
John, I brought a (cheap 15quid) grinder form B&Q took off the metal bits, wheels and replaced them with mops,
To be honest its underpowered at 150W and gets quite hot during use but it works ok for me  :tu:
« Last Edit: June 17, 2010, 12:58:25 PM by sparky415 »
spam Offline John
Reply #7 on: June 17, 2010, 01:30:06 PM
Tony  two birds with a single stone  ;) ok at £80+ a tad expensive but Xmas is not far off  :D
grinder and belt
us Offline eodtech
Reply #8 on: June 17, 2010, 01:31:57 PM
This stationary belt sander has a powerful 1/3-HP motor that moves at up to 3400 RPM for fast stock removal from your workpiece. Or fit it with a fine-grit belt (extra belts sold separately) for a smoother finish. A belt sander can also be used on non-ferrous metals; the sanding belt surface won't clog because it "opens up" as it goes around the drive wheel.
1" x 30" sanding belt, 80-grit
Table tilts 0° to 45°
Adjustable belt tracking
1-3/4" diameter dust-collection chute
Durable die cast and machined aluminum construction
Rubber feet minimize vibration
Motor: 1/3 HP, 120V, 3 amps, 60 Hz
http://www.harborfreight.com/1-inch-x-30-inch-belt-sander-2485.html
Reply #9 on: June 17, 2010, 01:32:22 PM
Want bench tools  :ahhh
Also want bench.... hmm.....
spam Offline John
Reply #10 on: June 17, 2010, 01:34:52 PM
I'll use my kitchen tops  >:D
Reply #11 on: June 17, 2010, 04:24:06 PM
Two nice tools there that I want now  :drool:
Nuphoria
Mostly I use my cheap 'workmate' as my bench is covered with boxes of useful stuff,
To make a workmate even more useful get a good flat bit of board (I use old kitchen cabinet doors) and screw a bit of 2''x 2'' to the back, then mount this in the workmate this makes a nice square work surface,
I have different ones for different clean/dirty/oily jobs some have holes drilled for dedicated machinery
I will see if I can take a pic later  :tu:
Reply #12 on: June 17, 2010, 09:08:42 PM
For people with out space for a workbench a workmate could be the answer as it can be folded up and put away when you are finished with it,
To make a workmate even more useful get a good flat bit of board, old kitchen cupboard doors are great for this, they are normally flat, square and easy to clean, the best bit is you can find them for free in skips and dumpsters
When you have a suitable board screw a bit of batten or 2'' x 2'' to the back you can then clamp it up in the workmates jaws
I have different ones for clean/dirty/oily jobs some have holes drilled for dedicated machinery
one of my vices ;)
Hope that is help full to someone, I think this adds a lot to the usefulness of a workmate  :tu:
us Offline eodtech
Reply #13 on: June 17, 2010, 09:14:22 PM
+1- have my original steel frame Workmate I purchased in 1975, it's sturdy and it's easy to store when not in use.
I also use a "top" on mine - mainly for working outside in the drive way on "messy"  projects such as grinding, sanding , spray painting, etc.
Reply #14 on: June 17, 2010, 09:24:29 PM
Eod
Sorry to send your thread off on a tangent  ::)
I have picked up lots of ideas over the years from blokes on building sites
As you can see mine was a very cheap one that I've had for probably more than 10 years, I think they are under rated by a lot of people  :tu:
spam Offline John
Reply #15 on: June 17, 2010, 10:12:38 PM
They're useful Tony I had one many years ago until someone walked off with it when I went indoors for a cupa  >:( I came back and well here's a pic of me at the time  :think:  :think:  :rant:  :D
us Offline Mike 56
Reply #16 on: June 18, 2010, 12:23:10 AM
I have a 3' X 6' table that is my portable bench from when i layed hardwood floors. My table saw and miter saw fit nicely on it at the same and you still have set stuff down.
Mike
