Wave Owners Club
Zed · 2900 · 184166
us Offline sergemaster
Re: Wave Owners Club
Reply #870 on: August 30, 2017, 07:47:47 PM
Amici,
Feeling a tad "tacticool" as I'm waving it today..
Cheers,
Serge
* Wave.jpeg (Filesize: 212.91 KB)
'I will NOT be threatened by a walking Meatloaf!!' - D. Kessler
Reply #871 on: August 30, 2017, 07:52:56 PM
 :like: :tu:
Reply #872 on: August 30, 2017, 10:50:41 PM
 :like:  :drool:
Reply #873 on: August 31, 2017, 01:01:35 AM
What Steve and Zed said :like: :like:
us Offline Spartan19
Reply #874 on: August 31, 2017, 02:29:24 PM
+1! :tu:
* DSCN2959.JPG (Filesize: 253.64 KB)
Send In the spartans
Reply #875 on: August 31, 2017, 02:52:13 PM
Reply #876 on: August 31, 2017, 02:59:41 PM
Thanks brother! :cheers:
hr Offline Jerry Drake
Reply #877 on: August 31, 2017, 04:31:33 PM
Let's try with Imgur
Reply #878 on: August 31, 2017, 05:16:17 PM
00 Offline Dutch_Tooler
Reply #879 on: August 31, 2017, 06:49:23 PM
Nice pic :)
Cheers!
Dutch_Tooler
Reply #880 on: September 01, 2017, 02:58:50 PM
Getting used hard today  :salute:
* 2017-09-01 12.28.12.jpg (Filesize: 292.31 KB)
hr Offline styx
Reply #881 on: September 01, 2017, 03:15:01 PM
lookin' good
Reply #882 on: September 01, 2017, 06:37:47 PM
us Offline JustinCase
Reply #883 on: September 02, 2017, 02:13:31 AM
“It's not that I'm so smart, it's just that I try a little longer to solve the problem"
gb Offline BePrepared
Reply #885 on: September 02, 2017, 04:09:02 PM
I think I finally have the perfect tool fit-out (for my uses) --- my Perfect Wave !
Reply #886 on: September 03, 2017, 12:38:13 AM
Awesome pics guys :tu: :like: :like:
Reply #887 on: September 03, 2017, 08:23:30 PM
 :like: Great pics everyone  :salute:
Reply #888 on: September 05, 2017, 08:55:41 PM
Amici,
One more time, but in Stainless and with more lumens..
Cheers,
Serge
* Wave EDC.jpg.jpeg (Filesize: 202.78 KB)
Reply #889 on: September 05, 2017, 08:58:52 PM
Amici,
Cheers,
Serge
 :like: :like:
Offline noah
Reply #890 on: September 30, 2017, 10:11:12 PM
First time poster, and this feels like a question that would have been answered but I've tried searching, to no avail. I've got a recently purchased Wave (two, in fact) which have the same issue; the safety pin what keeps the plain blade from opening when the pliers are in use has a tendency to keep the blade from be used when the tool is in the fully closed position (read: when I should be able use use the knife). Common problem? Fixable by the end user, or just treat it as a warranty item?
Reply #891 on: September 30, 2017, 10:47:55 PM
 I had the same issue with my Wave and fixed it by using a small file to remove material off  the tip of the pin, a little bit at a time, until the blade fold and unfold without rubbing or touching the pin.
Reply #892 on: September 30, 2017, 10:58:30 PM
Welcome aboard noah  :cheers:
It's not a problem that I've experienced. I'm going to assume that these weren't purchased new (correct me if I'm wrong). I would start with giving the wishbone (the forked spring) area a damn good clean, and getting some lubrication under it, to make sure there's not some gunk jammed under it that's holding it open, With the pliers only halfway deployed, the spring should not be forced over by the "ramp" at the back of the plier head. If it is still in "lock" position, I would try gently easing it back with a small screwdriver, in case something got really well jammed underneath it (don't try to do this with the pliers more than 90 degrees from the stowed position). If it's still not easing back, look for crack or signs of sprains near the base of the fork (just above the rivet that secures it to the body)
Good luck, and keep us informed. Other folks with other ideas may be along soon. Watch this space  :salute:
Offline noah
Reply #893 on: September 30, 2017, 11:41:48 PM
Both purchased new (one's a year or two older than the other) although it's much worse on one of them. On the "good" one, I can almost always open the blade, but even then I do feel the blade touch the pin on the way open. On the bad one, I generally can't open the blade at all if I've just closed the tool. Serrated blade is utterly unaffected on both tools. I'll take a closer look later and see what I can see.
Offline noah
Reply #894 on: October 02, 2017, 04:50:39 AM
No obvious issues, although I noticed that the plain blade on the bad tool is a stiffer to open than the plain on he good tool (or either serrated). Suspect I'll send it in for warranty work; s'what the warranty is for, after all.
Reply #895 on: October 13, 2017, 04:24:53 AM
Welcome to :MTO: noah and hope you can get the problem sorted :salute:
Reply #896 on: October 13, 2017, 04:25:03 AM
1012171655 by Poncho 65, on Flickr
wales Offline magentus
  • mmmmm SAKrelicious
Reply #897 on: October 16, 2017, 10:13:42 AM
Friend of mine found a LM in the middle of the road - said he was driving and spotted something out of the corner of his eye, stopped the car and waited as several other cars drove over whatever he had seen.
It was a Wave and was in excellent working condition despite the battering it received!
I may have to try a LM out sometime if they're as tough as they seem.
nz Offline Syncop8r
Reply #898 on: October 16, 2017, 11:41:55 AM
It was probably the mini driver he saw.
* Mr Bean.jpg (Filesize: 50.81 KB)
Reply #899 on: October 16, 2017, 11:43:04 AM
June Goal: $300.00
Due Date: Jun 30
Total Receipts: $139.46
PayPal Fees: $8.05
Net Balance: $131.41
Below Goal: $168.59
44%
June Donations
