(in this case the fullsize Trapper which happens to be the most collected slipjoint pattern out there) to see if you like it for very little money.2xTap
Are we talking about the same thing? I thought Sean was talking about the right side spring have a black line in the middle?
Quote from: 2xTap on August 21, 2010, 08:58:01 PM(in this case the fullsize Trapper which happens to be the most collected slipjoint pattern out there) to see if you like it for very little money.2xTaphey tap, why is it that the trapper is so popular with collectors? i really don't get the pattern personally. i think it's pretty but not near EDC standards IMO. functionally it's great if you're a trapper but most collectors aren't trappers. you'll get a lot less gunk on you during use on smaller critters but i don't see the intrigue for a collector. i do think the pattern can show off what the maker is capable of to certain degree. i'm not a collector but an accumilator i spose.on an aside: i have seen 'whitlers' by respected companies that are as far removed from what a whitler is that they can't even be called stockman.
If you don't mind me asking, what is it about Case's "Tru-Sharp" steel you don't like?2xTap
But I also don't whittle, the toughest material my slippies usually see is clamshell plastic and cardboard.2xTap
