no pics?.........
oooohhhhh yeahhhhhhhh Don't I just feel like a boss, finally jumped on the SRM bandwagon and nabbed a 710. Didn't have time to actually check it out properly or snap any pics but I will say I'm pretty impressed. Smooth and tight, cuts very well. I will say the hinge screw must be a bit too tight because opening it one handed was more of a challenge than it should have been. Ah well, time will take care of that I suspect. Expect a first-look video very soon on MGR.
Quote from: markn951 on August 17, 2010, 03:44:37 AMoooohhhhh yeahhhhhhhh Don't I just feel like a boss, finally jumped on the SRM bandwagon and nabbed a 710. Didn't have time to actually check it out properly or snap any pics but I will say I'm pretty impressed. Smooth and tight, cuts very well. I will say the hinge screw must be a bit too tight because opening it one handed was more of a challenge than it should have been. Ah well, time will take care of that I suspect. Expect a first-look video very soon on MGR.I got one last week and I am QUITE impressed. I had to loosen the pivot screw a quarter turn to make it easier, but it still locks up quite soldily without any play. I think my next project is to make a leather slip case for it (I removed the pocket clip), then maybe fill the pocket clip holes with GitD material.
Quote from: Freudian Frog on August 17, 2010, 04:41:46 AMQuote from: markn951 on August 17, 2010, 03:44:37 AMoooohhhhh yeahhhhhhhh Don't I just feel like a boss, finally jumped on the SRM bandwagon and nabbed a 710. Didn't have time to actually check it out properly or snap any pics but I will say I'm pretty impressed. Smooth and tight, cuts very well. I will say the hinge screw must be a bit too tight because opening it one handed was more of a challenge than it should have been. Ah well, time will take care of that I suspect. Expect a first-look video very soon on MGR.I got one last week and I am QUITE impressed. I had to loosen the pivot screw a quarter turn to make it easier, but it still locks up quite soldily without any play. I think my next project is to make a leather slip case for it (I removed the pocket clip), then maybe fill the pocket clip holes with GitD material. Hm, I have to remember to do that then! Yeah, I only tested it with paper but boy does it slice!!
Quote from: markn951 on August 17, 2010, 04:48:41 AMQuote from: Freudian Frog on August 17, 2010, 04:41:46 AMQuote from: markn951 on August 17, 2010, 03:44:37 AMoooohhhhh yeahhhhhhhh Don't I just feel like a boss, finally jumped on the SRM bandwagon and nabbed a 710. Didn't have time to actually check it out properly or snap any pics but I will say I'm pretty impressed. Smooth and tight, cuts very well. I will say the hinge screw must be a bit too tight because opening it one handed was more of a challenge than it should have been. Ah well, time will take care of that I suspect. Expect a first-look video very soon on MGR.I got one last week and I am QUITE impressed. I had to loosen the pivot screw a quarter turn to make it easier, but it still locks up quite soldily without any play. I think my next project is to make a leather slip case for it (I removed the pocket clip), then maybe fill the pocket clip holes with GitD material. Hm, I have to remember to do that then! Yeah, I only tested it with paper but boy does it slice!!Before you loosen the pivot screw, try this - instead of pushing the thumbstud straight up to open, use the finger choil on the knife as a guide to push it up and out at a slight angle. Once I figured out how to do that on my 763s, the blades came flying out of the handles where I had problems beforehand.Practice it a bit and it'll become second nature to you.
I got my 3 for exduct, total was like 27 bucks or something but man the shipping took like 3 weeks.
