Vic corkscrew driver for LM small bit
Offline Andreas
on: August 21, 2010, 01:17:43 AM
Not really a mod since I didn't make it permanent, just something I discovered in a moment of boredom: if you remove the metal part of the Vic corkscrew screwdriver it will hold the bit from the lm small bit driver
Offline Andreas
Re: Vic corkscrew driver for LM small bit
Reply #1 on: August 21, 2010, 08:52:40 AM
Forgot to add (wrote the original post on my iphone at night): as is it's too long to fit into the corkscrew, so using this method would require you to cut the bit in half before inserting. Had I had a spare bit, I would have done that - I find a small Phillips hear is more useful than a small flat head, simply because a small flathead can normally be traded for eithe the tip of a knife (yeah, bad I know) OR the small flathead on the can opener.
